Activity › Forums › Panasonic Cameras › Urgent DVCPRO HD – Final Cut PRO workflow question
  • Urgent DVCPRO HD – Final Cut PRO workflow question
    Posted by Cantinflas on January 21, 2006 at 1:20 am
    We’re shooting a movie with Panasonic’s VARICAM at 23.98 fps and have an older DVCPRO HD deck with no firewire support (the AJ-HD130DCP). I’d like to capture from the deck HD-SDI to Final Cut Pro through Deckline HD Pro maintaining the source quallity. I read that Final Cut Pro will only admit this frame rate via firewire. Is this true? Is their a workaround?
    Thanks to everyone in advance, Alex.
    Chris Bell replied 20 years, 8 months ago 2 Members · 1 Reply
  • Chris Bell
    January 21, 2006 at 4:49 am
    Nope, not true. You can edit Varicam material at 23.98 uncompressed via HD-SDI. You need to make sure your hardware is compatible with that frame rate.
