Activity Forums Blackmagic Design Urgent DVCPRO HD – Final Cut PRO workflow question
  • Urgent DVCPRO HD – Final Cut PRO workflow question
    Posted by Cantinflas on January 21, 2006 at 1:16 am
    We’re shooting a movie with Panasonic’s VARICAM at 23.98 fps and have an older DVCPRO HD deck with no firewire support (the AJ-HD130DCP). I’d like to capture from the deck HD-SDI to Final Cut Pro through Deckline HD Pro maintaining the source quallity. I read that Final Cut Pro will only admit this frame rate via firewire. Is this true? Is their a workaround? Can anyone suggest a proper workflow for this gear?
    Thanks to everyone in advance, Alex.
    Juan Salvo replied 20 years, 7 months ago 2 Members · 1 Reply
  • Juan Salvo
    January 21, 2006 at 9:31 am
    No, it’s not true. No need for a work around use the Blackmagic 720p 23.98 easy setup.
