Activity Forums Adobe After Effects URGENT-credit roll flicker
  • URGENT-credit roll flicker
    Posted by Franky Torres on May 24, 2007 at 8:05 pm
    Okay,
    so I am creating a 2k end credit crawl in after effects, to be filmed out for a feature. I am on the final version, but 1 of the notes I got back from the client, is that the crawl has a flicker/strobe to it. All text layers are parented to the 1st layer, which has 2 key frames animating the text across screen. I already applied an expression to the positional keyframes on the animated layer [Math.round(position[0]),Math.round(position[1])] so that there are no positional values with decimals, only whole numbers. Can anybody give me anymore tips to make the crawl look correct? Or is the expression the only thing I have to do?
    I have to render at 3:00 in order to get this out the door in time. Any advice?
    Franky Torres replied 19 years, 4 months ago 2 Members · 3 Replies
  • Kevin Camp
    May 24, 2007 at 8:24 pm
    how fast is the credit roll?
    if the move is too great between frames then the roll will seem kind of jerky or strobe-like regardless of restricting to whole pixel movement.
    try doubling the credit roll duration and see it still seems strobe-like.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Franky Torres
    May 24, 2007 at 8:28 pm
    9 secs roll…text enter at frame 1 and exits at second 9
  • Franky Torres
    May 24, 2007 at 8:39 pm
    So I guess my last question, since the client has only seen the version before the expression was applied; Am I good to go with applying the expression (which I only did today) and having text scroll for a 9 second duration?
