Activity Forums Apple Final Cut Pro Legacy URGENT Converting SD project to HD
  • URGENT Converting SD project to HD
    Posted by Eldon Pernel on June 4, 2008 at 12:04 am
    I really need help….I have this music video I’m working on…It was shot on HD 1080i ….I really thought I had open up the HD template to start building sequence on my timeline…when I have almost finish…it was brought to my attention I was editing SD normal 720 x 480 DV…..that really hurts …can you help me and let me know what can I do to restore to original HD…my client is on my back!!!
    DESPERATE!!!!!!..:-)
    Ed Dooley replied 18 years, 3 months ago 5 Members · 4 Replies
  • Simon Webb
    June 4, 2008 at 3:49 am
    Is the digitized footage SD or HD? I realize it might be a dumb question, but if it was shot in HDV, your deck’s “i.link” output settings might have been set to DV rather than HDV. It’s happened to me once… Once.
  • Lu Nelson
    June 4, 2008 at 8:37 am
    If your footage is in SD DV (and not just the sequence settings) you treat it as an offline and redigitize.
    Select your sequence in the bin and run Media Manager -> Create Offline, with the *new* offline project sequence set to the correct type (HD 1080 whatever) and this will create a new project with all the clips offline (unconnected to media). Select all your offline clips in this new sequence and Batch Capture..
    Hopefully your recapture will come through without any sync problems — as long as none of the original clips were very long, like more than a few minutes or so, it should be alright
    Lu Nelson
    Berlin, Germany
  • Jeff Carpenter
    June 4, 2008 at 1:53 pm
    Simon and Lu are giving you the ‘worst case’ situation.
    If you’re lucky, it’s not the footage but just the sequence. Open a clip in the viewer and tell it to display at 100% size. That will give you your answer real quick!
    If it is HD footage in a DV timeline, just make an HD timeline and copy everything in the old timeline and paste it in the new one.
    It will likely all be re-sized wrong. You can select everything and right-click it to ‘remove attributes.’ You can reove the motion setttings and everything should re-size correctly.
    If you’d previously re-sized a clip during the edit you may have to re-do that again.
    Let us know how it goes.
  • Ed Dooley
    June 4, 2008 at 6:13 pm
    Urgent, Urgent, Urgent!!!
    Next day, nothing.
    Ed
