  • Posted by Maurik De ridder on February 28, 2006 at 3:32 pm
    have to deliver asap clips to a client…
    have to convert fcp movie to flv which i use sorenson..
    the sequence setting is set to pal anamorphic (wide screen 16:9)
    but when i convert it into fcp movie (which i then can load into sorenson), it looses it’s widescreen and becomes squeezed
    how can i convert my sequences into a fcp movie and preserve my widescreen settings
    anyone help me urgently… the client becomes inpatient
    thanks
    Maurieketje
    Maurik De ridder replied 20 years, 6 months ago 2 Members · 2 Replies
  • Eli Mavros
    February 28, 2006 at 3:42 pm
    File>Export>Using Quicktime Conversion….then go into the options and there is an option for size…put in your widescreen dimensions and then export…should be a work around.
    -Eli
    Eli Mavros
  • Maurik De ridder
    February 28, 2006 at 4:29 pm
    thanks eli, you saved my day
