Upside Down & Green?????????????
Ever run in a problem like this?
Could you direct me please to a solution.
https://www.anthonychristianproductions.com/test.wmvRecently changed video cards from a GeForce 6800 GS to a Quaro FX 1500.
I communicated with PNY NVIDIA to confirm I had the correct driver
for this card installed. I do.It worked previously before the video card switch..
The video link I provided shows me scrubbing across the timeline where
in which the video preview box shows the video in its correct colors and upright.
However , when I hit play on the timeline it plays upside down and has
a green tint to it.A few things I have done that have not proven successful:
Created a new sequence
Create a new project
Many restarts
Check for correct driver
Scratch Disk is located in its correct place (recently added some hard drives)Other important facts:
Files are CFHD
Premiere Pro 2.0
Captures are coming from Sony HVR-A1 & HVR-V1UMS XP Service Pack 2
AMD Athlon 64X Dual Core Processor 4600+
2.41 GHz, 2.00 GB of RAMRAM TYPE: Patriot Signature 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit System Memory
https://www.newegg.com/product/product.aspx?Item=N82E16820220057&ATT=20-220-057&CMP=OTC-streetpricesSYSTEM BOARD: GA-K8N51GMF-9
https://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1939PROCESSOR TYPE: AMD Athlon 64X Dual Core Processor 4600+
https://www.sharkyextreme.com/hardware/cpu/article.php/3565416Any Clues???????????????????????
Fred
