Activity Forums DaVinci Resolve Upside down clips
  • Upside down clips
    Posted by Jules Bodenstein on June 23, 2011 at 8:52 am
    I’m currently experiencing a bizzar issue with Da Vinici. I am importing the edl of the reels of a feature film (shot on Red, offline on Avid, transfered using file16 edls) and for one of the reels davinici seems to have flipped the frame on about 25% of the clips so that they are upside down.
    I’ve had a look through the edl at the effected area but cant notice anything out of the ordinary.
    Anyone got any ideas of a solution (as the best I can come up with is getting the colourist to grade while doing a handstand)?
    Gaz
    Gaz Evans
    Workflow Technician
    The diROOM
    https://www.diROOM.com
    Jules Bodenstein replied 15 years, 2 months ago 3 Members · 3 Replies
  • Margus Voll
    June 23, 2011 at 9:32 am
    Maybe avid changed media ?
    Margus
    https://iconstudios.eu
  • Peter Chamberlain
    June 23, 2011 at 9:46 am
    Hi, are the source images conformed by Resolve the red r3ds? Check the clips in the media pool, right click and look for H flip and V flip, these may be set by the red camera metadata as the would be for a stereo project. You can easily deselect this if needed.
    If it’s not this, you can use resolve to flip the image, check format input tab.
    Peter
  • Jules Bodenstein
    June 23, 2011 at 10:48 am
    Thanks for that – it worked like a charm!
    Gaz Evans
    Workflow Technician
    The diROOM
