Activity › Forums › VEGAS Pro › Upscaling SD to HD – is that required?
  • Upscaling SD to HD – is that required?
    Posted by Jaanus Henno on November 5, 2012 at 11:21 am
    Hi!
    I’m editing old SD material and I’m wondering what’t the best output format for them? Most of it will be viewed on computer screens, well, maybe someone has a HD TV. In any case, I would like it to be compatible with the latest technology for avoiding any possible problems in the future. These are mostly mpeg-2 files, 4:3. I will make them widescreen.
    Does upscaling improve the quality? What’s the best settings to use in Vegas Pro 11?
    Thank you!
    John Rofrano replied 13 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    November 5, 2012 at 9:12 pm
    Boris Continuum Complete has BCC UpRez that will do a nice job of upscaling your SD to HD. You can purchase it alone as a Continuum Unit and you can download a trial to see if you like the results.
    If you just want to use Vegas, I would create a project at the resolution you want to deliver at and use the sharpening filter on the track that has SD content. I won’t look as good UpRez but it might be OK.
    Here is my tutorial from Boris TV on how UpRez works:
    Episode #86: UpRez SD footage to HD in Sony Vegas Pro 10
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jaanus Henno
    November 6, 2012 at 11:55 am
    Thank You John, it worked out great!
    I tried the trial version and the results are visibly better than simply rendering to HD resolution. And thanks for the tutorial, wouldn’t be able to figure out without that.
  • John Rofrano
    November 6, 2012 at 3:04 pm
    You’re welcome. I’m glad you found the tutorial useful.
    ~jr
