Activity › Forums › Adobe After Effects › Upscaling a DV composition
Posted by Matt Radbourne on November 10, 2009 at 9:17 amHi all
What’s the easiest way of upscaling a DV PAL spec composition to 1080p?I’ve got an animation that contains Illustrator vectors, After Effects live text and DV video in sub-compositions (creating a flying video screen in the animation).
Any help would be much appreciated. Cheers
Matt Radbourne replied 16 years, 10 months ago 5 Members · 11 Replies -
Walter Soyka
November 10, 2009 at 3:54 pmI’d only upres and replace the video clips, not the entire comp. To preserve detail on the vector art and text, you could try nesting the DV PAL comp in an HD comp, scale it up, and collapse transformations.
Walter Soyka, Principal
Keen Live, Inc.
Presentation, Motion Graphics & Widescreen Design
RenderBreak: A Blog on Innovation in Production -
Matt Radbourne
November 10, 2009 at 5:02 pmThanks Dave
It’s set up as an anamorphic comp at the moment.I agree with you – I’d much rather do the upscaling pre-render. Something like what Walter is suggesting I think.
Matt Radbourne
November 10, 2009 at 5:11 pmGreat. So if I nest a comp at 200% and click the collapse transformations switch then the vectors and text (obviously not video) will be rendered as if they were all placed on the final comp at 200% size individually, i.e. not pixellated?
Walter Soyka
November 10, 2009 at 5:19 pmThat’s exactly how it should work, but remember to double-check that Continuously Rasterize is checked for each vector layer.
What’s more, if you up-res each of your video clips individually, replace the SD clips with the new up-ressed HD clips in your DV PAL sequence and scale them back down to fit in as the originals did, Collapse Transformations will preserve your resolution. In other words, a 400% blowup of a 25% reduction will look like the original at 100%, instead of a hideous pixellated mess.
Keen Live, Inc.
Kevin Camp
November 10, 2009 at 5:20 pmin theory, yes… but it doesn’t always work out that easily. collapse transformations can change how some effects look and, if you have 3d layers, it can effect their properties in unexpected ways. but you won’t know until you try.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Matt Radbourne
November 11, 2009 at 11:37 amArgh. One last thing:
I have 3D camera paths. As soon as I collapse the transformations, the camera work is ignored. Any way to preserve this?Matt Radbourne
Media Designer
CEM, UK -
Matt Radbourne
November 11, 2009 at 12:46 pmHopefully found the solution: https://forums.creativecow.net/thread/2/960672
Matt Radbourne
Media Designer
CEM, UK -
Walter Soyka
November 11, 2009 at 2:07 pmThat looks like a great tip — please let us know if it works out for you.
Keen Live, Inc.
Michael Szalapski
November 16, 2009 at 10:29 pmYou mention you’ve got a 3d camera which reminded me of one way I uprezzed a few projects I was working on.
What I did was duplicate the composition or save it as a different project (so you can always go back if/when you screw up). Then make your composition the size you need.
Then I went to all the AE-created solids in the comp and resized them (by highlighting your shape layer and pressing ctrl+shift+y).
Then simply use the zoom on your AE camera and zoom in closer.
It won’t work for every situation, but it worked for me. I only had to tweak one or two other things. It saved me hours of work.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
