Activity Forums Compression Techniques Upscaling 720p noise problem
  • Upscaling 720p noise problem
    Posted by Adam Speas on January 17, 2009 at 1:25 am
    I am trying to upscale some P2 footage from 720p into 1080p. I’ve tried using Apple Compressor to do so, and when the shots are moving then things look decent and it appears like it could pass QC. But on the static shots I see plenty of noise. I’ve tried different settings and the noise removal filter on Compressor, but it just doesn’t seem to eliminate enough noise that makes it passable. Is there a better method to go about doing this, software to help with the noise problem, or a system that would give little as noise as possible?
    Thank you,
    Adam
    Daniel Low replied 17 years, 8 months ago 2 Members · 1 Reply
  • Daniel Low
    January 17, 2009 at 11:47 pm
    Please provide a screenshot of the ‘noise’.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
