  • Posted by Brian Tario on April 23, 2007 at 11:35 pm
    This is a not-so-sexy topic in an edit suite…the UPS. But it’s necessary and I need a bigger one. A few months ago the incomparable Bob Zelin suggested I buy the APC Smart UPS 1500RM-2RU. Well, I haven
    Joe Murray replied 19 years, 5 months ago 4 Members · 6 Replies
  • Stuart Ferreyra
    April 23, 2007 at 11:47 pm
    We use the same APC unit Bob told you to get. I think I replied to your post as well.
    The 1500 is plenty. We have a Mac, and Xserve Raid and CRT monitor hooked up to each UPS.
    In case of a power failure the battery is not going to last for an hour or two, but enough
    minutes for you to save and close all apps.
    Stuart Ferreyra
    Timecode Multimedia
    President
    Santa Monica, CA 90025
    https://www.timecodemultimedia.com
  • Brian Tario
    April 23, 2007 at 11:55 pm
    Thanks Stuart! What about the Mac OS’s ability to safely shutdown the RAID and the Mac? That’s really the key for me. I don’t care if I only get 10 minutes of runtime as long as the shutdown is safe and automatic if I’m out at lunch.
  • Stuart Ferreyra
    April 24, 2007 at 12:14 am
    I do not use it, but I have tried it.
    As soon as you connect the USB cable, OS X will show a preference pane in the preferences
    window with options for the APC UPS.
    I do not remember why I disconneted it. There was something I didn’t like about it, but that
    was more of a personal preference than anything else.
    The unit works as is advertised.
    Stuart Ferreyra
    Timecode Multimedia
    President
  • David Roth weiss
    April 24, 2007 at 12:48 am
    Brian,
    As Stuart mentioned, you forgot to mention plugging in a monitor to your UPS. If you don’t have, at the very least, your main system monitor plugged in to your UPS you will not be able to navigate to manually shut everything down and only an auto shutdown will work.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Brian Tario
    April 24, 2007 at 12:55 am
    Very true, thanks to both of you for your help! Brian
  • Joe Murray
    April 24, 2007 at 2:03 am
    CRTs pull more power than anything else you’ve got on your list. We don’t use the battery backup for CRTs, instead we just use surge suppression for those since you don’t lose any data when they shut down. And the LCD monitor for your computer isn’t going to pull nearly as much as the CRT broadcast monitor.
    Joe Murray
