Activity › Forums › Apple Final Cut Pro Legacy › Uprezzing project
Uprezzing project
Posted by Sherwood Ball on November 25, 2006 at 4:28 amI have edited and outputted my doc as DV NTSC 4:3.
I now need to make the project be HDCAM 1080/60i
What is the best way to do this?
1) re-output the project, and if so, what is the process?
2) uprez the master QT?
What has been tried and true for best digital projection resolution
for a theater?Thnx.
SherwoodG5 Dual 2.5 GHz
4G Ram OSX4.6
Sata drives
Final Cut Studio 5.1.1, Logic Audio 7.1
PS CS2, AE CS2Sherwood Ball replied 19 years, 10 months ago 4 Members · 11 Replies -
Shane Ross
November 25, 2006 at 5:45 am[S.E. Ball] “What is the best way to do this?”
Take your tape to a facility that has a Terranex and run it thru that onto a D5 or HDCAM tape.
Next best thing, recapture the file with a Kona 3 as 10-bit uncompressed 1080i then output that to tape. But the full-on Terranex box has terrific noise reduction capabilities.
No idea about projection. If the place has a D5 or HDCAM deck, just playing it off that should be fine. But, depends on the projector.
Shane
Littlefrog Post
http://www.lfhd.net -
Kent Kajino
November 25, 2006 at 10:53 amIf your source material is SD, then I hear a lot of people play back from DigiBeta.
Mine was in HD, so I played back from HDCAM.
Either way, the biggest problem I found with many theaters is the audio playback. The older houses don’t accomodate 5.1ch playback from a video deck unless you rent all the necessary decoders and stuff such as Dolby-E, which I hear are expensive. And Lt/Rt was a big let down for the sound mixer. To get 6 discreet chanels, I would have had to rent a D5 or HDCAM SR deck. (the projectionist kept telling me to play from a DVD, which does surround sound decoding) Thinking back, BluRay or HDDVD might have been a good compromise.
Sherwood Ball
November 25, 2006 at 6:13 pmI never said anything about surround or audio problems.
I’m uprezzing from SD to HD in stereo.Shane’s suggestions are sound.
I will see about doing a test with the Terrazino.Thnx.
Sherwood Ball
November 25, 2006 at 6:28 pmI did my original output as uncompressed QT’s.
Never laid back to tape.There are twelve uncompressed/lossless QT’s (DV_NTSC_48kHzStereo) that make up the total feature.
Should I re-export these QT’s as a dif rez?
Maybe do a test at the original native output and then with a slightly
larger rez with the Terraex……Thnx
G5 Dual 2.5 GHz
6G Ram OSX 4.8
Sata drives
PS CS2, AE CS2 -
David Roth weiss
November 25, 2006 at 6:44 pmSherwood,
The answer to your question is not quite as simple as a one pass uprez. Because your original is DV, your titles and graphics will all become mush. To really handle this properly you need split out all titles and graphics from the entire project — uprez the video on Terranex — put your your graphics on an HD timeline and redo as necessary — combine the new HD video and the your graphics and titles on the HD timeline.
DRW
David Roth weiss
November 26, 2006 at 8:17 amSherwood,
Or, you could just project SD from tape — it’ll look great, especially on a really good video projector. Doing HD may be a lot more trouble than its worth, but only you can answer that…
DRW
Kent Kajino
November 26, 2006 at 6:15 pmSorry, I just assumed that if you’re doing hidef at a theater, you might have created a 5.1 surround mix.
Just telling you about the mistakes I’ve made, so noone else will. My sound supervisor was really pissed when she found out the theatre could only do stereo, unless I had a film print. I also got a couple of complaints about the non-surround playback from the audience, as well.
Sherwood Ball
November 27, 2006 at 12:51 amThank you for sharing with us.
The festival requirement for digital projection is HDCam/1080/60i.
Whaddaryagonnado?Stereo will have to do at this point.
I could output some of the ambience, explosions, etc to dif audio outputs
during eventual HD layback……. good idea.THNX.
G5 Dual 2.5 GHz
6G Ram OSX 4.8
Sata drives
PS CS2, AE CS2 -
Sherwood Ball
November 27, 2006 at 12:52 amWhat about my AE vid clips I created?
Can I just re-render at higher rez?
Thnx.
G5 Dual 2.5 GHz
6G Ram OSX 4.8
Sata drives
PS CS2, AE CS2
