  • Posted by Rob Alexander on November 15, 2007 at 10:36 pm
    I’ve cut an SD sequence which the client tells me he needs as an HD 720p movie. Can I get some advice as to workflow?
    I’ve exported my sequence to a quicktime movie 720×576 PAL 25fps 8 bit Uncompressed.
    Now I’ve created a 720p 25fps sequence (1280×720).
    Imported my quicktime and set it to anamorphic (which it is).
    Placed the movie into the 720p sequence and scaled it to fit the frame then rendered it.
    Then I plan to export it H264 1280×720 QT.
    Does this sound OK? What happens to the interlacing – do I need to do anything?
    Thanks in advance for tips,
    Rob
    Rob Alexander replied 18 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
