Activity › Forums › Apple Final Cut Pro Legacy › UPREZ workflow- must EFX be done after?
  • UPREZ workflow- must EFX be done after?
    Posted by Justin Ferar on July 20, 2005 at 6:28 am
    I’m interested in producing higher quality DVDs. As I understand it uncompressed video makes a better DVD.
    Everything is shot on DVCAM and is digitized as DV.
    I have already completed a program and would like to uprez- should I uprez to DV50 or Animation?
    Also, I already performed all compositing and EFX in the DV timeline. Can I just drop this timeline into a hi rez timeline and render? Or must all compositing and EFX be performed in the hi rez timeline?
    I would appreciate any tips on this and would also like to know if the process is even worth the uprez considering that the footage is all DV anyway.
    Thanks in advance.
    Dual 2.7
    Medea RAID w/ATTO UL3D
    Graeme Nattress replied 21 years, 2 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    July 20, 2005 at 1:11 pm
    The “damage” was done when you shot DV… you cannot improve it by putting it into an uncompressed sequence. In fact, theory states that you actually are losing some quality doing so… So for now, stay all DV… FCP 5 has the ability to improve render quality BTW over FCP HD… If you really want improvement, you need to shoot digibeta, DVCPRO50 or better in the first place. I really don’t think you’ll see any improvement putting DV into a higher qualtiy sequence…
    Jerry
  • Graeme Nattress
    July 20, 2005 at 1:51 pm
    But, by doing the final render in an uncompressed sequence, you don’t loose quality by that final render back to DV and all your effects will look better. By placing a magic chroma filter like G Nicer (From Film Effects) on each DV clip you can boost the chroma nearly up to DigiBeta standards, and hence make a much improved DVD at the expense of the extra render time. Even just adding Apple’s 4:1:1 chroma smoother will help as NTSC DV’s 4:1:1 clashes with DVD’s 4:2:0 quite badly. Smoothing or fixing the chroma first really helps.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Dan Riley
    July 20, 2005 at 3:17 pm
    Graeme is right about how to make your DV footage look better.
    Also, titles look much better uncompressed.
    Any key effects you do will look better uncompressed.
    Shooting DVCAM and finishing uncompressed is not a bad
    workflow. Of course as Jerry said, shooting Digibeta is
    nice too. But you do what you can.
    You need a video card and a fast drive array though.
    This isn’t just about selecting a different codec.
    It’s much more involved to edit and playout uncompressed.
    It’s worth it in my opinion but there is some expense.
    Go to Aurora, AJA or Blackmagic.
    Dan
  • Justin Ferar
    July 20, 2005 at 9:48 pm
    Graeme,
    By having already completed all my compositing in the DV timeline is it too late to to uprez? In other words should I have just done a cuts only edit in DV, then bring into a higher rez timeline and then do compositing etc.
    I ask becuase I am wondering what FCPs render flow is. When I drop a DV progam into a Hi Rez program it neads to render. My real question is will it re-render all the nested effects at Hi Rez or just take whatever is in the program (already rendered as DV) and Up Rez that.
    Question number two is: If I never rendered the DV timeline AND THEN dropped it in a Hi Rez timeline, would all the nested compositing and EFX be rendered as animation or DV50 or whatever the Hi Rez codec is?
    Hmmm?
  • Graeme Nattress
    July 21, 2005 at 2:34 am
    FCP always re-renders to produce the best quality, so no, it’s not too late. What I tend to do is just dupe the DV sequence and then change the settings on the dupe to be uncompressed etc.
    Graeme
