Activity Forums DaVinci Resolve Uprez to Cinema Scope 2.39 from 1080
  • Uprez to Cinema Scope 2.39 from 1080
    Posted by Andrew Smith on March 3, 2014 at 6:19 pm
    I am grading a 1080p 23.98 project with 2.39 output blanking and the client wants to deliver 2.39 aspect ratio but at a resolution of 2048×858. How best to do this – Resolve/AE/etc?
    Andrew
    Timo Teravainen replied 12 years, 5 months ago 5 Members · 10 Replies
  • 10 Replies
  • Michael Phillips
    March 3, 2014 at 6:54 pm
    I would create that XY in Resolve, conform, color, or whatever needs to be done and then export as same XY. You may need to apply a scale/resize depending on your sources and if they have letterboxing or not (if they are coming from Media Composer).
    Michael
  • Michael Phillips
    March 3, 2014 at 6:57 pm
    If you have letterboxed finished clip, then look to After Effects to do the resize/scaling. They have added some very nice quality uprez in their latest CC version.
    Michael
  • Andrew Smith
    March 3, 2014 at 7:23 pm
    Thanks for the reply – just curious to respond, its coming from fcp7 xml and is 1080p 23.98, I am grading with 2.39 output blanking ON in Resolve.
    They want two:
    1) 1080 full frame w/out 2.39 crop
    2) 2048×858 w/ 2.39 crop
    I have both Resolve and AE CC – can you possibly explain in a little more detail how to do in both apps so I can compare quality/results?
    Thank you
  • Andi Winter
    March 4, 2014 at 12:08 am
    if they want that resolution, they wanna go dci, i would say.
    last time i did this i did the resize in davinci, and it did a great job.
  • Andrew Smith
    March 4, 2014 at 2:43 am
    Thanks andy so how best to do this in resolve exactly?
  • John Sellars
    March 4, 2014 at 2:49 am
  • Set Timeline Resolution to 2k 16:9
  • (2048×1152)
  • In Output Scaling set to scale full frame with crop
  • Remove output blanking
  • Deliver at 2k DCI Scope 2.39
  • Resolve has a very good “optical quality” scaler. I would be curious to see if AE could do better.
  • Andrew Smith
    March 4, 2014 at 2:08 pm
    Ok great thanks John, any one know how best to do this in latest version of AE CC – I am hoping to compare the quality between the apps and report back my findings in this thread.
    Cheers
    Andrew
  • Timo Teravainen
    March 8, 2014 at 9:20 pm
    In AE, make a new comp with the 2048×858 dimensions. Then drag the footage to the comp, and scale it to 106,67%, if it’s 1920×1080. Render to DPX 10 bit or 16 bit, make sure the project bit depth is also at least 16 bit.
    I wouldn’t do a XYZ conversion in Resolve (or AE..) Easy DCP and Final DCP both do a good job.
    Also interested to hear about the difference between AE and Resolve scaling. I’ve had good experience with Resolve before.
  • Michael Phillips
    March 8, 2014 at 9:36 pm
    This is the new feature I would want to as part of a test between the different scalers. Adobe calls it Detail preserving upscale and you can see a quick video here: https://tv.adobe.com/watch/adobe-at-ibc-2013/after-effects-cc-detailpreserving-upscale/
    Michael
  • Timo Teravainen
    March 9, 2014 at 8:12 am
    That’s really interesting, didn’t know about it, still myself on CS6..
  • We use anonymous cookies to give you the best experience we can.
