UpRez: more than just SD->HD?
Posted by Dan Weissman on October 24, 2011 at 5:39 pmUpRez is promoted for its usefulness as a SD-to-HD tool.
Could I also use it to upscale a portion of a shot that originated in HD — in other words, to let me crop and enlarge a corner of the frame?
thx in advance,
– DanDan Weissman replied 14 years, 11 months ago 2 Members · 4 Replies -
Peter Mcauley
October 24, 2011 at 8:47 pmHi Dan,
I think the best way to go about this would be to crop the image in Photoshop and then to use the BCC UpRez filter to perform the scale routine to bring the cropped portion of the clip to HD.
Cheers,
Peter.
Dan Weissman
October 24, 2011 at 10:06 pmHi Peter,
Thanks, but I think I didn’t make clear that this isn’t for a still, it’s a motion shot, and I assume I can’t do what you’ve suggested in Photoshop.
Which brings me back to UpRez. Do you know if it (or some other plug-in!) can be used to work on a selection of a frame (cropped for enlargement), or is it only for uprezzing a full-screen image (ie, full DV-to-HD)?
Thanks in advance,
— Dan -
Peter Mcauley
October 24, 2011 at 10:52 pmHey Dan,
I understand better now your request.
So with that, here’s my recommended workflow:
• In After Effects or any other compositing or editing solution, position and frame the clip so that the portion of the clip that you are interested in using is centered in comp. You’ll use the comp size as a way to crop the clip.
• Then render out the clip to disc.
• Import the clip into the compositing or editing solution where you are going to use UpRez and follow the recommended steps for uprezzing the clip within that host. There are instructions for this in the help file of the UpRez filter.
By the way, which host are you using for all of this work?
I hope this helps.
Cheers,
Peter.
Dan Weissman
October 25, 2011 at 4:21 amHi Peter,
A workflow walkthrough!!
You are gentleman and a scholar (and who knows what else).
We’re in FCP 7, btw.
Thanks so very much,
– Dan
