Activity Forums Apple Final Cut Pro Legacy Uprez dvcpro-HD
  • Uprez dvcpro-HD
    Posted by Ben Hendriks on May 31, 2009 at 8:21 am
    I need to uprez some 960×720 footage to 1440×1080 or even 1920x 1080.
    No tape but P2 cards. I know Kona does a great job, but I don’t have a Kona board and I do not need to go to tape for delivery.
    Any experience with software uprez apps?
    Best Ben
    Gary Adcock replied 17 years, 3 months ago 10 Members · 22 Replies
  • 22 Replies
  • Walter Biscardi
    May 31, 2009 at 9:55 am
    What you need to do is an HD cross conversion from 720p to 1080i. That’s not a “uprez”. There’s no software I could recommend for that other than maybe Shake. Hardware only is what I would use.
    In your case, I would lay off the 720p material to our Panny 1400 decks and then recapture the footage to 1080i via our AJA Kona 3 boards which perform the conversion in realtime.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Ben Hendriks
    May 31, 2009 at 10:20 am
    Hi Walter,
    So going from 960x720p to 1920x1080p is not an uprez?
    Uprez does not mean going up in resolution?
    OK. Thanks for your response.
    Best Ben
  • Walter Biscardi
    May 31, 2009 at 11:30 am
    [Ben Hendriks] “So going from 960x720p to 1920x1080p is not an uprez? “
    No, it’s an HD Cross Conversion.
    Read my Blog!
  • John Pale
    May 31, 2009 at 4:18 pm
    Compressor does a nice job with basic cross conversion
  • Arnie Schlissel
    May 31, 2009 at 9:00 pm
    [John Pale] “Compressor does a nice job with basic cross conversion”
    Yup. I’d try that first. If you’re not happy with the results, try Shake, AE, Combustion, maybe Photoshop Extreme.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Rafael Amador
    June 1, 2009 at 2:00 am
    Funny, in Laos we call that Upscaling, upsizing or so.
    This of cross-conversion sounds to pure marketing.
    rafael
    http://www.nagavideo.com
  • Ben Hendriks
    June 1, 2009 at 10:23 am
    Hi Rafael,
    Same here, I think there is nothing “cross” about going from 720 25p
    to 1080 25p. Just UP. Maybe the Kona manual has something to do with it.
    Well, not realy important…….
    Thanks for the responses,
    Ben
  • Walter Biscardi
    June 1, 2009 at 10:39 am
    [Rafael Amador] “This of cross-conversion sounds to pure marketing. “
    Cross Conversion is when you take one HD format and convert it to another HD format. This applies to the conversion of 720 to 1080 and 1080 to 720. This is why it’s called a cross conversion.
    That’s the term that was explained to me when I started working in HD 5 years ago and it’s the proper term for making this conversion. You can call it whatever you like, but I prefer to use the correct broadcast terms in my responses.
    Read my Blog!
  • Rafael Amador
    June 1, 2009 at 11:18 am
    [walter biscardi] ” I prefer to use the correct broadcast term”
    Walter, the problem is that today there are no such “broadcast terms”.
    Years ago institutions like the SMPTE, EBU, etc, set the terms and specs and the industry have to follow them.
    Todays is the other way round and manufacturers use terms like “cross conversion” that is absolutely meaningless but it sound very well in a brochure.
    rafael
  • Herb Sevush
    June 1, 2009 at 4:43 pm
    Rafael –
    I disagree with the idea that the term “cross conversion” is empty marketing hype. Up-Rez means going from standard def to ANY HD format. Cross-Conversion means going from one HD format to another. Compared to the difference between standard def and any form of HD, the differences between the various HD formats is insignificant. for instance I can make the case that going from 720P60 to 1080i invovlves no expansion of data whatsoever, just a change between temporal and physical dimensions. So for convenience sake we have the term “cross-conversion” which indicates a change in format without any significant change in quality and “up-rez” which indicates an enormous change in quality.
    Herb Sevush
    Zebra Productions
Page 1 of 3
