Activity Forums Boris FX UpRez and Deinterlace
  • UpRez and Deinterlace
    Posted by Dino on January 28, 2011 at 7:11 pm
    I want to do both. UpRez and Deinterlace. I have the plug in for each. They each work independently, can’t make them work together. In After Effects.
    latest version of the plug ins, AE CS4, Mac Pro OS X 10.6.4
    Anyone have some advice?
    Dino replied 15 years, 7 months ago 2 Members · 2 Replies
  • John Rofrano
    January 29, 2011 at 3:26 am
    [Dino Sanacory] “I want to do both. UpRez and Deinterlace. I have the plug in for each. They each work independently, can’t make them work together. In After Effects.”
    You have to precompose the SD source file with deinterlace first. Make an SD composition the size of your clip and add deinterlace to that. Then create a HD composition with a solid and UpRez and use the SD composition as the source for UpRez. You should now have deinterlaced, UpRezed footage.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dino
    February 1, 2011 at 12:58 pm
    John. That’s the stuff. Thanks for the tip.
