Activity › Forums › Apple Final Cut Pro Legacy › upres / mixed footage question
  • upres / mixed footage question
    Posted by Mark Wilkinson on September 30, 2009 at 5:13 pm
    our project is now ( yes, i know, foolishly… ) mixing anamorphic PD150 footage and Canon 5D footage. After reading some posts here I got Instant HD and tried upping ( after deinterlacing with RE Vision ) it way way way up to the 5Ds resolution and that was obviously a bit much for it. my next idea is bringing the 5D stuff down and the PD150 stuff up but to a lesser degree and put them both in a 1280 X 720 progressive sequence. does this sound like a reasonable compromise ?
    Mark Wilkinson replied 17 years ago 3 Members · 3 Replies
  • Shane Ross
    September 30, 2009 at 5:30 pm
    What is your FINAL MASTER going to be? Always figure that out first, then work backwards…to figure out what you need to do to best accommodate that goal.
    Shane
  • Rafael Amador
    September 30, 2009 at 5:33 pm
    [mark wilkinson] “. does this sound like a reasonable compromise ?”
    Sure.
    You may use Compressor, setting Control Frame ON, and Better resizing.
    The DV footage will upsize better if you de-interlace it.
    rafael
    http://www.nagavideo.com
  • Mark Wilkinson
    September 30, 2009 at 7:14 pm
    ok thanks for those answers. the delivery is to a film festival and i have just emailed them to get specifics. maybe going to DigiBeta would make sense in the end or just a DVD ?
    on that front, if it is going to end up on a DVD is it still better to work on a progressive timeline or would it make sense to go the other way and interlace the 5D footage ?
