upres from SD to HD
Posted by Karl Dixon on October 22, 2012 at 8:48 pmI’m producing an HD short for broadcast and must mix-in some SD footage with some 1920*1080 footage, does anybody have an idea what to use in order to upres SD to HD ?
I work on Vegas.
Thank you guys.Mike Kujbida replied 13 years, 10 months ago 2 Members · 5 Replies -
Mike Kujbida
October 22, 2012 at 9:03 pmI just did this with at least 30 SD clips this past weekend.
Drop them on your 1920*1080 timeline, open up Pan/Crop and do a Match Output Aspect and resize/crop if necessary, and render.
I rendered everything to 1920*1080 60i MXF format because that’s what my final delivery format will be.
The SD footage was soft in comparison to the HD material but it was better than I had expected. -
Karl Dixon
October 22, 2012 at 9:20 pmwell the question is: how do you do that match output aspect? i don’t see that option anywhere
Mike Kujbida
October 22, 2012 at 9:23 pmGo into pan/crop and right-click anywhere. It’s one of the options that comes up.
Karl Dixon
October 22, 2012 at 9:52 pmi tried it, unfortunately it didn’t work: the new HD render is way too pixelated…
Mike Kujbida
October 23, 2012 at 3:21 amI was afraid of that 🙁
Something you can try is a product from Boris called UpRez that I’ve heard good things about.
A trial version is available and, if you like it, it’s only $99.00
https://www.borisfx.com/units/upRez.php
