Activity Forums Adobe After Effects Upper or Lower Field First in AE3
  • Upper or Lower Field First in AE3
    Posted by Glen Thompsett on November 22, 2008 at 3:40 pm
    I’ve just created a nice title sequence with an animated ‘shimmering’ background strap using one of the AE templates. I’ve exported it as a QT movie and imported it into Avid Media Composer, but the end result is quite disappointing. It seems to judder and the font looks very washed out – is it something to do with the Lower & Upper Field setting in AE3?
    I’d really appreciate any help.
    Thanks.
    Kurt Murphy replied 17 years, 9 months ago 2 Members · 1 Reply
  • Kurt Murphy
    November 23, 2008 at 12:52 am
    The Avid is usually 720 x 486, lower field first – is that the size you made it? Try a test, create a white xo traveling across the screen over 3 seconds; render one out upper field, and one out lower field. Import both into the Avid to see which looks good and which stutters.
    Hope this helps,
    kurt murphy
