Activity Forums VEGAS Pro upper field to lower field
  • upper field to lower field
    Posted by Nicholas Mcadorey on September 20, 2006 at 9:11 pm
    First let me say hi from sunny South Africa.
    My question is this : We use Pal here and dv is lower field first but everything else seems to be upper field first, so once i’ve capt & edited and want to render out to do some touch ups in AE, my only option is the normal dv avi format (or to export aaf if no effects are used), but what if i want to render at a higher quality ie pro50 or sony yuv, both of these will only render upper field first (same from AE to vegas). Is there a solution to this as upper field looks really bad on my preview moni and i’m not sure if just right clicking on the clip and changing the field order will correct it.
    thanks in advance.
    Nicholas
    Earthcubed from sunny SA
    Nicholas Mcadorey replied 19 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
