Activity Forums Adobe After Effects upper field lower fields.. or progressive??
  • upper field lower fields.. or progressive??
    Posted by Mohit Woody on September 22, 2006 at 10:20 pm
    my output medium is going to be cinema screen (PAL) and dvd’s.
    so which settings i choose.. i using progressive.. and i think it seems to be fine.. when i use upper or lower fields.. it gives those wierd lines.. like interlacing..
    pls advise..
    thanks.
    Mohit Woody replied 20 years ago 2 Members · 2 Replies
  • Andrew Kramer
    September 23, 2006 at 2:29 am
    What is your source material? Progressive is best if you shot progressive…
    Andrew Kramer
    http://www.videocopilot.net
  • Mohit Woody
    September 23, 2006 at 8:06 pm
    well my footage is actually animation which i rendered out frm 3ds max.
    if i use upper or lower.. both cases i get those ugly interlacing lines.. so im using progressive.. but jst wanna make sure.. this works whn my output is converted to film.
    thanks.,
