Activity Forums AJA Video Systems upgrading to LHi or MXO
  • upgrading to LHi or MXO
    Posted by Donato M. rondinelli on December 15, 2009 at 9:05 pm
    I’m looking into upgrading our 3 broadcast suites to mac intel. We’re using LH now. LHi looks like where I want to be since I still need analog audio. Is Kona still the way to go? Should I consider the MXO for broadcast?
    -dMR
    Alex Desrial replied 16 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    December 15, 2009 at 9:12 pm
    LHi, no question.
    Jeremy
  • Shane Ross
    December 16, 2009 at 7:58 am
    Just to be the voice of reason…or an alternate voice…either will suit you well. What I like about the MXO2 is that I can use it on my laptop AND my tower. Both do analog, both do SDI…both upconvert/cross convert/downconvert.
    Now the LHi has a leg up in a couple areas. It will upconvert 4:3 to crop full screen…the MXO2 will do Pillarbox only (and anamorphic). And the upscale of the LHi is slightly better than the MXO2. Have to look at the scopes to see it, but it is there.
    But then again, the MXO2 can be used on a laptop, can run off a battery (standard Aaton Baur)…and up until a while ago it was the only one that did embedded closed captioning. Now they all do.
    If you have towers only, and no need for using one on a laptop, then the LHi might be the one for you.
    I have used the Kona LHe, Kona 3 and MXO2 and like them all. It all boils down to the minor differences in feature sets.
    Shane
  • Donato M. rondinelli
    December 16, 2009 at 1:01 pm
    Thanks guys. Good information.
    -dMR
  • Matthew Causon
    December 16, 2009 at 1:57 pm
    Hello gents
    I’m not an expert on the Matrox products but there may be some other areas that could be important to you and worth investigating.
    Kona product have been very developed over the years e.g.:
    Range of supported video formats;1080p, 1080p50/60 etc.
    525i 29.97
    625i 25
    720p 50
    720p 59.94
    720p 60
    1080i 25
    1080i 29.97
    1080i 30
    1080PsF 23.98
    1080PsF 24
    1080P 23.98
    1080P 24
    1080P 25
    1080P 29.97
    1080P 30
    1080P 50
    1080P 59.94
    1080P 60
    AJA Kona applications:
    https://www.aja.com/products/software/
    Kona LHi up/down/cross and SD/SD ARC is also very developed (same technology as Kona3/FS1/IoHD), Shane mentioned the upconversion, but here’s the data from the brochure:
    Up-Conversion
    Hardware 10-bit
    Anamorphic: full-screen
    Pillar box 4:3: results in a 4:3 image in center of screen with black sidebars
    Zoom 14:9: results in a 4:3 image zoomed slightly to fill a 14:9 image with black side bars
    Zoom Letterbox: results in image zoomed to fill full screen
    Zoom Wide: results in a combination of
    zoom and horizontal stretch to fill a 16:9 screen; this setting can introduce a small aspect ratio change
    Down-Conversion
    Hardware 10-bit
    Letterbox: image is reduced with black top and bottom added to image area with the aspect ratio preserved
    Crop: image is cropped to fit new screen size
    Cross-Conversion
    Hardware 10-bit
    1080i to 720P
    720P to 1080i
    720P to 1080PsF
    SD to SD Aspect Ratio Conversion
    Letterbox: This transforms SD anamorphic material to a letterboxed image.
    H Crop: Will produce a horizontally stretched effect on the image; transforms anamorphic
    SD to full frame
    SD Pillarbox: Will produce an image in the center of the screen with black borders on the left and right sides and an anamorphized image in the center
    V Crop; Will transform SD letterbox material to an anamorphic image.
    For more info on Kona:
    https://www.aja.com/pdf/KONA_Line09.pdf
    As Shane says the LHi is for Tower computers only. If Laptop use is needed the IoHD and IoExpress are AJAs portable offerings.
    Best regards
    Matty Causon
    Phosphor
    EMEA Business Management for AJA Video Systems Inc.
    December 16, 2009 at 2:06 pm
    Thanks Matty. I’m happy with the flawless performance of my LH/LHe cards. I’ve owned them for 4 years and never had an issue. If only FCP worked that well :o)
    -dMR
  • Matthew Causon
    December 16, 2009 at 3:27 pm
    Hello Donato
    Good to hear.
    And the cards are still current models so a pretty good investment.
    thx
    Matty Causon
    Phosphor
  • Alex Desrial
    December 16, 2009 at 8:32 pm
    Hi Mike,
    Go a head with LHi, no doubt, customers we set-up with LHi are very excited indeed. Rich of convertion capabilities like kona 3, support both analog and digital worlds like your current LH/LHe, and HDMI In and out like the IO HD.
    Alex Desrial
    MediaIntegra – Jakarta
