Activity Forums Apple Final Cut Pro Upgrading to 10.1.4 issues from 10.0.8
  • Upgrading to 10.1.4 issues from 10.0.8
    Posted by Mitchell Alexander on January 13, 2015 at 8:20 pm
    Hello, I have a problem with recently upgrading. I had been using FCP X from early on and never upgraded for fear of not being savvy enough to do it. So I recently did the upgrade and my fears came true. I updated and yet not all my projects and events were properly upgrade. They’ve become lost in the sea of the “Updated ” folder the new upgrade creates. So on this one particular drive, it only updated one event and project out of four. The others are still sitting in the old version in that folder but there’s no way of getting the “Update projects and events button to link to them and update those particularly.
    Does anyone know how to do that? Can I undo the halfway done upgrade and do it again?
    Mitchell
    Robin S. kurz replied 11 years, 8 months ago 3 Members · 2 Replies
  • Eric Santiago
    January 14, 2015 at 2:19 pm
    Have you tried deleting the currentversion.flex file?
    Do it with FCPX off and see what happens at after re-starting.
    Ive had to do this a few too many times but it worked for me.
    Other steps were to re-import (Drag and drop at times) all the associated media and hope it re-links with the Project.
  • Robin S. kurz
    January 15, 2015 at 1:56 pm
    The only thing you want to do is read up on the best path/system for upgrading first. I would simply delete everything from the new version (but not any flex anything), then start HERE https://www.philiphodgetts.com/2013/12/upgrade-your-events-and-project-to-fcp-x-10-1-libraries-the-better-way/ then move HERE https://www.rippletraining.com/fcpx-features.html after all is said and done for a full understanding of what’s going on under the hood.
    If you do what Philip suggests and also grasp the (new) underlying concept you shouldn’t have any problems at all. It should just take a little while, depending on the amount of events/projects.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
