Activity Forums Panasonic Cameras Upgrading my FCP system
  • Upgrading my FCP system
    Posted by Luiggi Berrios on November 16, 2007 at 12:13 pm
    Hi, I just need some advice since I have been editing for the past 4 years without any problems on a Dual 1.25/G4 using a Promax DA Max as a converter to input analog stuff from either Beta SP or DVD to the machine. Most of the stuff that I do is just simple editing and from time to time a do a proyect in After Effects and Motion. I considering buying a brand new Imac 24″ with the latest 2.8 processor and FCS 2. Is this machine will do the work for me considering what I do, can I edit a P2 footage proyect on it? Please give me an advice…
    Agnes Marsala replied 18 years, 8 months ago 3 Members · 3 Replies
  • Shane Ross
    November 16, 2007 at 4:14 pm
    Depends…what do you need to deliver? If ONLY DVDs, this system should work. But if you need to output to any sort of tape, you’ll need a capture card, and those only work in Towers. Even the I/O HD would require the firewire bus all to itself, and since the ONLY drives you can use on an iMac are firewire…this wouldn’t work.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Agnes Marsala
    January 16, 2008 at 3:13 pm
    Shane,
    Why won’t the ProMax work for output? I’m using one too and I’m going to be upgrading my system soon. The ProMax has both in and out analog signals. I was hoping to keep it and spend more on the Mac.
  • Agnes Marsala
    Shane,
