Activity Forums Audio Upgrading my AKG 568B shotgun mic
  • Upgrading my AKG 568B shotgun mic
    Posted by Rob Dunford on November 13, 2014 at 1:38 pm
    I have had my 568 for some time and used mainly for street interviews. It has worked well. The only downside is that I have found the sound quality quite a bit different from my other mics, AT4053 and 4051. So there is always the issue of trying to match the response.
    Now a sound guy has offered me an AT 4073 in good condition and I’m wondering if this would be a better match and also a better mic than the 568.
    Comparing specs, I see the AT mic is a lot more sensitive to handling noises and the roll off is higher.
    Has anyone used both and can give me some greater insight?
    Or maybe I should look elsewhere for a replacement. Budget is constrained….
    Ty Ford replied 11 years, 10 months ago 2 Members · 3 Replies
  • Ty Ford
    November 13, 2014 at 5:09 pm
    Hello Rob and welcome to the Cow Audio Forum.
    Wow, an AKG 568b. I’ve never heard of one (and I’ve heard a lot of mics).
    The AT4073 is very sensitive. This can be a very good thing for nature videography, but horrible if you’re shooting around a high noise environment.
    Have you tried your 4053?
    My Schoeps cmc641 works very nicely outside. It’s a similar configuration, just a lot smoother.
    Maybe try the 4053 to see what you can get out of it before spending the money on the 4073.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Rob Dunford
    November 13, 2014 at 10:23 pm
    Hi Ty, thanks for the comment. TBH I have tried the 4053 instead of the AKG and been pleasantly surprised in situations i wouldn’t have expected good results. Maybe I should just save up for a 416 instead….
  • Ty Ford
    November 13, 2014 at 10:30 pm
    I find I use my Schoeps cmc641 super cardioid a lot more than my 416, 816 or NTG8.
    If you haven’t heard one of those, you should try one.
    Regards,
    Ty Ford
