Activity › Forums › DaVinci Resolve › Upgrading mid-project
Posted by Jesse Glucksman on September 12, 2012 at 10:36 pmSorry if this was answered before–I scanned through the threads and did not see.
Have any of you had experience upgrading to Resolve 9 in the middle of a project? I’ve been holding off because I have a bunch of work left on a film and don’t want to risk something going irreparably wrong if I upgrade and the project gets funky for whatever reason. I love 8 anyway, but everyone speaks highly of 9.
Joseph Owens replied 14 years ago 8 Members · 11 Replies -
Peter Berg
September 12, 2012 at 10:49 pmHi Jesse,
Unless you absolutely need any of the new Version 9 features, I strongly urge you to hold off on upgrading.
I am running into some new problems that I did not have with Version 8. Also 9.0 seems a little bit less stable.
I would have stayed with 8, but there was an audio playback bug (with UltraStudio) that would not be fixed in Resolve 8.
I’ve always found it better to wait till my big projects are done, before I change anything on my currently working system.
-Peter
Robert Houllahan
September 13, 2012 at 12:18 amI wouldn’t ……
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
Andrew Smith
September 13, 2012 at 2:07 amYeah I agree DO NOT do it. I made that mistake but it was not my choice.
I am seeing a bunch of bugs and stability issues on V9 beta and regular V9 release.
Kinda surprised it got released out of beta with these blatant bugs.
Kevin Cannon
September 13, 2012 at 2:29 amHi Jesse,
I’ve been using a dual-boot configuration with 8.2.2 on 10.7 and v9 betas on 10.8.
I’ve opened up the same project in both, and did get different results. Mostly it seemed like the difference was coming from this: I did an XML import in 8.2.2 and certain resizes or opacities or whatever were not being supported. The same project in v9b2 or 3 did support more of the XML features, and therefore different results.
Not the end of the world, but on a certain project could be a huge headache. Especially if you have a lot of manual resizes, etc. And there could be more things like this I haven’t encountered.
KC
Nick Anderson
September 13, 2012 at 3:34 amCreate a new database in v8, import ur project, upgrade in v9. Take a whole day, test it urself.
Sascha Haber
September 13, 2012 at 7:34 amThats what I did…never looked back.
A slice of color…
DaVinci 9b3 OSX 10.8
MacPro 5.1 2×2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+Colorist / Aerial footage nerd
https://vimeo.com/saschahaber -
Joseph Owens
September 13, 2012 at 4:32 pmGenerally it is NEVER, NEVER, NEVER, NEVER x10^9 a good idea to change horses midstream — with the one in a billion chance that a point release, not a version release, will cure a bug.
If you were to attempt a version change, I would save every grade in the original version and be prepared to hand copy them back into the migrated project. The grades, individually, are very likely to be valid, but as has been discussed, the actual image adjustments are only a small part of the overall workflow in terms of stages that are likely to be (in engineering terminology) f***d up.
jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
Sascha Haber
September 13, 2012 at 5:08 pmThe pony Express ALWAYS changed horses midways 😉
A slice of color…
RAID0 8TB
