Activity › Forums › DVD Authoring › Upgrading from DVDSP to Encore CS4? Good idea?
Posted by Jessica Berryman on October 1, 2009 at 6:18 pmI would like to find a more professional DVD authoring program that is compatible with a Mac. It also needs to accept photoshop files and after effects as well. Is this the best option available and will Encore CS4 be compatible with CS3?
Jessica Berryman replied 16 years, 12 months ago 4 Members · 11 Replies -
Noah Kadner
October 1, 2009 at 8:17 pmCS3 what?
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, and Panasonic DVX100.
https://www.callboxlive.com
DSLR Cinematography Blog -
Michael Sacci
October 1, 2009 at 8:25 pmI would not say that Encore is a more professional authoring program.
But you are flowing in two different directions. More “Professional” to most professionals is going to mean spec level authoring (Scenarist) which is really high $ and steep learning curve but you can process finely tuned DVDs.
The Other direction are programs that integrate Photoshop and AE files into the authoring workflow, such as DVDSP (with PS files) and then even better is Encore, but this does not make them more “professional” authoring tools, in fact it makes them less. This is not to say they are not professional, just that they are not “more.”
If Encode does everything you need it to do and you like the any it works with the other Adobe software use it. It is not a better app then DVDSP at best it is a sideways more, but if being able to go back and forth a little more easily with PS and AE is the main thing then it maybe worth it.
I would say more people that have used both seem to like/use DVDSP over Encore but there are those that like Encore better, Jon G for one, these are just tools, use what fits the best in your hands, at the end of the day all that matters is that you have the disc you want.
Jessica Berryman
October 1, 2009 at 8:33 pmHmm. Could you give me a few names of what you would recommend for the “professional” authoring programs. The costly ones? If I am creating DVDs that are going to be duplicated and sold should I pick something a little higher end than DVDSP or Encore?
I’ve just been using DVDSP a lot over the past year and I’ve found some issues with the program that don’t make it as user friendly as needed.
Jessica Berryman
October 1, 2009 at 8:45 pmOk.. I just did my research. Sonic Scenarist is the “professional” is there any other programs.
Michael Sacci
October 1, 2009 at 8:49 pmIf you find DVDSP to be “not user friendly” don’t even look at spec level authoring.
Scenarist is the major full spec DVD authoring program, it is what most Hollywood titles are being authored with. I believe it is still about $50K for the software, it is PC only but if you are paying 50K for the software putting together a PC should be a big deal.
Now DVDSP can and does produce “professional” DVDs, and it does it in a fraction of the authoring time but the cost is heavy code that is being written in the background. This is why it is so easy to author with but this code is not always the most direct way of going something but you can do 90% of what can be done with a DVD with DVDSP. What Scenarist allows you to do is fine tune the code (navigation) but to do this you need to know DVD specs. (Example jumping from a movie to ANY MENU on the disc is not a one step process, there are domains that you need to jump out of before you can jump into another.
So once again, more user friendly and more professional are not going in the same direction.
Eric Pautsch
October 1, 2009 at 9:28 pmActually Scenarist 3 is around $7,000 now. They drastically dropped the priced since no one was buying them anymore. 🙂
Jessica….its important to learn how DVD technology works before you decided what is “professional” and what is not. Read this book and this website if you really want to know the technology. When you understand all this, I think you will find that DVDSP will provide all you need.
https://www.dvd-replica.com/DVD/
What kind of features does DVDSP not provide for you?
Another tool to check out is DVD Lab Pro:
https://www.mediachance.com/dvdlab/dvdlabpro.html
Michael Sacci
October 2, 2009 at 7:40 amSD DVD has pretty much been frozen application wise. Not much happening. I remember now getting an email a long time ago about the pricing. I got over the Sonic boat with Creator on the Mac.
Eric Pautsch
October 2, 2009 at 8:15 amYeah that boat left long ago! Ahhh…I remember the good old days before DVDSP 1/2. 🙂
Jessica Berryman
October 2, 2009 at 12:58 pmThanks Eric! I will definitely check these books out and do more research into these programs.
Eric Pautsch
October 2, 2009 at 8:40 pmAnother site and book to buy:
https://www.dvddemystified.com/
But just a warning – make sure you know what you’re getting into before you buy Scenarist. It will takes years to FULLY master.
