Activity Forums Apple Final Cut Pro Legacy Upgrading from Cinewave
  • Upgrading from Cinewave
    Posted by Ray Kivinski on July 5, 2007 at 8:46 pm
    Hello All
    Well I’m finally ready to retire my Cinewave SD system (Dual 2 GHz PowerPC G5) and move up to a Kona LHe on a Mac Pro Eight Core Xeon 3GHz. Having no projects in the works, what steps would you take to retire the Cinewave – still would like to have access to old files.
    Barry Atwood replied 19 years ago 3 Members · 3 Replies
  • Barry Atwood
    August 9, 2007 at 10:29 am
    i have an even older cinewave system (dual 500 G4) working fine but must transition into the present. also wonder about how to access ‘old files’ after i make the move. is there a codec available that will work??
  • Walter Biscardi
    August 9, 2007 at 10:47 am
    The AJA Kona 2Vuy codec will read CineWave files just fine. So if you want to save off your files in their native CineWave codecs you can. Or you can simply convert all your files over to Uncompressed 4:2:2 using Quicktime Pro.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Barry Atwood
    August 9, 2007 at 1:01 pm
    i am very greatful for the response! if there are resources (in addition to the forums) that you would steer me to as i configure a new fcp system please do so. again, thanks!
