Activity › Forums › Blackmagic Design › upgrading from camera/firewire capture to SDI uncompressed with Decklink
  • upgrading from camera/firewire capture to SDI uncompressed with Decklink
    Posted by Chad Treanor on April 6, 2005 at 3:43 pm
    Im thinking of moving from my camera/firewire digitizing method to getting a deck and capture card so I can capture uncompressed DV footage. I’d really like to see if this capture card I have in mind (from Decklink) is worth getting. Its only in the $280 to $300 range and seems like Decklink has the rep. to be a great capture card manufacturer. On the B&H page their summary states that this card works in conjunction w/Premiere Pro and thats what I’m cutting on these days.
    I’d like to also see what kind of deck I would have to purchase to work with this card to achieve uncompressed DV. How much do DV decks with component YUV out cost? I’d like to get a deck that can play and record DVCAM and MiniDV tapes but also be able to capture and output Uncompressed DV footage. How much do the component cables run? Are they regular BNC’s? Will the Deck use the RS-422 control plug?
    Does capturing with a card like this require more RAM?
    Will I need to buy a seperate set of Drives to fit all this uncompressed video? Whats the difference in file size according to one second of uncompressed DV compared to firewire compressed DV footage?
    Anything I should look out for with my PC while doing this upgrade? Any advice would be really appreciated.
    Chad Treanor
    Dell XPS
    Windows XP Professional
    Adobe Digital Video Professional Package
    3.2 Ghz processor
    1 gig of ram
    280 gigs of storage
    Heres the link to the card I was looking at.
    https://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=286847&is=REG
    Kaspar Kallas replied 21 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • Dalen Quaice
    April 6, 2005 at 4:32 pm
    You’d need a deck such as the Sony DSR-1500A which is about $5750 and an DSBK-1501 SDI option board for $1099.
    SDI uses 75 ohm BNC cables – they are about $13.00 each for 6 feet length.
    You need a computer that supports 64 bit PCI-X slots. The Dell XPS you mention does not have this, so you couldn’t use Decklink on that machine. You’d need to get a Dell Precision “workstation” class machine or a similar motherboard with at least 2 gb of RAM and a striped RAID of at least 2 SATA or SCSI discs.
  • Graeme Nattress
    April 6, 2005 at 4:47 pm
    And you won’t get any better picture quality – so why bother??
    Graeme
    – http://www.nattress.com – Film Effects for FCP
  • Chad Treanor
    April 6, 2005 at 5:03 pm
    I thought that if you edit uncompressed DV footage that the quality of the image looks better than that of composite firewire video? Is this not true? Ive watched certain productions that were edited uncompressed on (component DV) media 100 machines that look better than productions that were created on like a FCP w/a camera firewire-ing in the footage.
    I suppose my desire for more professional equipment blinded me from looking into the engineering aspect of this upgrade.
    Thanks again.
    Chad Treanor
  • Graeme Nattress
    April 6, 2005 at 5:22 pm
    Editing DV uncompressed is only of value if mastering to a higher format such as Digital Betacam, and even so, this does not require you to capture it uncompressed, as DV is always DV.
    However, Quicktime does not smooth DV chroma, so if bumping to a higher format you should do this by:
    1) capture component will smooth chroma, but will introduce noise and artifacts due to an analogue process being involved – not recommended
    2) capture over SDI uncompressed. Easiest workflow if you’ve got the gear to handle it, but you need big fast drives, SDI card and SDI equipped DV deck
    3) capture Firewie, smooth with Apple 4:1:1 chroma smoothing filter
    4) capture Firewire, use my G Nicer chroma reconstruction filter. Does nicest job, but slowest to render.
    Graeme
  • Kaspar Kallas
    April 6, 2005 at 5:34 pm
    You DO NOT NEED pci-x for SD SDI card
    You DO NOT NEED raid for uncompressed 10 bit work (sata drives are about 30MB/s on slow and it is enough for 10bit 4:2:2)
    You DO NOT NEED a new deck if you are willing to do the conversion in software – I don’t know about PC but mac even captures from firewire to 10 bit in realtime
    Make Your investments where it counts and don’t belive everithing you read
    -Kaspar
  • Dalen Quaice
    April 6, 2005 at 6:45 pm
    Decklink requires at least a 64 bit PCI 33/66 slot. Desktop motherboards such as the Dell desktop systems WILL NOT WORK because they have standard 32 bit PCI slots. You need a “workstation” class machine. You do not have to have a Dual Xeon machine to do standard def, you can use a Supermicro P4SCT+II.
  • Dalen Quaice
    April 6, 2005 at 7:24 pm
    That is a topic of debate. I too feel that DV looks better when edited uncompressed. The keys, compositing, and graphics added while editing are cleaner when you are working with uncompressed – and you don’t lose a generation re-rendering like you would working in the lossy Apple DV codec.
    There is a helpful site that compares codecs:
    https://www.onerivermedia.com/codecs/
    You can see how each holds up render after render. Look at generation 10 Apple DV! Yuck!
  • Graeme Nattress
    April 6, 2005 at 7:32 pm
    But if you’re mastering to DV you’re no further forwards, other than have wasted a tonne of disk space. Indeed, because of the filtering the SDI output does to the chroma, you could have slilghtly worse quality after going back to a DV deck over SDI rather than keeping in DV throughout.
    And if you’re outputing to digital Betacam, there’s no need to capture you DV uncompressed, just, when done editing as DV, flip the sequence over to an uncompressed setting and re-render. The Apple DV codec is very much as good as the hardware at decompressing DV. The difference is in the chroma smoothing, for which, see my above post.
    Graeme
  • Kaspar Kallas
    April 7, 2005 at 7:25 am
    All the SD cards are 32 bit and work fine in all computers that can handle the data
    64 bit slot is double size
    I have tested the card in P4 with 32 bit PCI slot and works like a charm
    Also I have tested it in opteron box in 32 bit and 64 bit slot worked in both
    64 bit slot is almost double lenght from 32 bit (like pci-X)
    SO YOU DO NOT NEED 64 BIT SLOT
    -Kaspar
