Activity › Forums › Apple Final Cut Pro Legacy › Upgrading from 6.0.4 to 6.0.6
  • Upgrading from 6.0.4 to 6.0.6
    Posted by Peter Humble on August 26, 2010 at 3:57 am
    When I try to upgrade it’s telling me I need 6.0.5 which I can’t find anywhere on the Apple Site.
    I’ve noticed users on the forum mentioning that you should use the Apple Software Update Utility however when I try this it doesn’t find FCP at all and I can’t see anyway to search this utility.
    Any suggestions?
    Peter
    Peter Humble replied 16 years ago 2 Members · 4 Replies
  • Zane Barker
    August 26, 2010 at 4:45 am
    [Peter Humble] “I’ve noticed users on the forum mentioning that you should use the Apple Software Update Utility however when I try this it doesn’t find FCP”
    Im betting you have moved the apps out of the app folder or manually put them in a sub folder. Software update only checks the app folder to see what you have installed.
    **Hindsight is always 1080p**
  • Peter Humble
    August 26, 2010 at 5:01 am
    Bingo…thank you.
    I didn’t realise that.
    So in that case would you discourage placing subfolders in Applications folder?
  • Zane Barker
    August 26, 2010 at 5:02 am
    [Peter Humble] “So in that case would you discourage placing subfolders in Applications folder?”
    YES if you want folders to put in the dock for sets of apps then create aliases and put those in folders.
  • Peter Humble
    August 26, 2010 at 5:22 am
    Thanks for your help.
    It’s all updating smoothly now
