Activity Forums Apple Final Cut Pro Legacy Upgrading FC Studio except Final Cut
  • Upgrading FC Studio except Final Cut
    Posted by John Dehn on September 23, 2005 at 11:49 am
    I’ve had the FC Studio box sitting in my edit suite for a couple of weeks now, and just can’t find a break in projects where I feel comfortable going from FC 4.5 to 5. However, I want to start using Motion, Soundtrack Pro, and DVD Studio right away. Do you think I’ll run into any problems installing those components now and upgrading FC later?
    -Thanks
    jd
    Jeremy Garchow replied 21 years ago 4 Members · 6 Replies
  • Steve Eisen
    September 23, 2005 at 12:52 pm
    Install the complete suite. Before you install, RENAME FCP 4.5. If you don’t, FCP Suite will overwrite your FCP Application. This will alow you to have both FCP 4.5 and 5.0 on your system.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 2.45 TB External Stor
  • Jerry Hofmann
    September 23, 2005 at 1:28 pm
    Don’t think that Motion 2 will interact well with FCP 4.5 for sure… I’m not seeing a lot of problems opening 4.5 projects in 5… I’d duplicate a 4.5 project first however, and keep a version of 4.5 running as suggested by Steve… I did this by using a second startup disk for the new Studio… I’m running a dual boot system now, but really haven’t had much occasion to run the 4.5 system anymore.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • John Dehn
    September 23, 2005 at 1:29 pm
    Do I only need to rename the application itself? What about the preference and other files, will they be overwritten?
    -jd
  • Jerry Hofmann
    September 23, 2005 at 1:35 pm
    Actually, they won’t because they have a different name…
    Jerry
  • John Dehn
    September 23, 2005 at 2:19 pm
    Jerry:
    So if I install everything on a new drive instead, then I just have to change my startup drive when I shut down each time, right? Also I paid for the upgrage to FCP Studio not the full package. Will that cause me a problem when I’m trying to upgrade to a new system drive? All in all I really like the idea of putting this whole new box on a new drive and upgrading to Tiger as part of it.
    -jd
  • Jeremy Garchow
    September 23, 2005 at 2:44 pm
    Not to speak for Jerry, but when you install FCP 5 upgrade it will ask you for your old serial numbers from all applications so have those handy. I did the same thing (installed tiger and fcp 5 on a different drive) and have not looked back. I’m with Jerry that since upgrading, i have rarely booted into 4.5 except to finish my older projects. ALthough, I did not upgrade any projects, I finished what I had in 4.5 and started new ones in 5 and I’m pretty much running 5 exclusively on two machines here. Even though it’s possible to have both versions running on one system, I would recommend keeping them separate.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
