Activity Forums Avid Media Composer Upgrading Avid mid project
  • Upgrading Avid mid project
    Posted by Dan Crouch on May 15, 2014 at 11:32 am
    I am about to upgrade my Avid Media Composer from vers 3, to version 6.5 to be in synch with my main cutting room.
    Very simple question, should I delete my version three software first then download and upgrade?
    Then simply pull in the bins?
    It works fine when I take my synch pulls up to the main edit and pull them into MC6.5 there, it’s just that I am mid project and quite a distance away from my main post house.
    Thanks for any help on this.
    Dan
    Dan Crouch replied 12 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Glenn Sakatch
    May 15, 2014 at 2:03 pm
    obviously in a perfect world, you would wait till the project is complete, but situations arise when “best practices” need to be ignored.
    I would assume the rules will be the same for 3 as later versions. You will be told to uninstall the software before the new version will install. Just back up your projects folder before proceeding.
    In an extreme case you could always rollback to 3, but you shouldn’t have any issues.
    Glenn
  • Dan Crouch
    May 15, 2014 at 2:46 pm
    Thanks Glen, good tips.
    I have a break coming up in the edit for a few days, will do it then.
    Thanks again,
    Dan.
  • Graham Tees
    May 15, 2014 at 3:35 pm
    You would also need to de-activate your registration before un-installing, so that you can then activate the new version.
  • Shane Ross
    May 15, 2014 at 5:09 pm
    Clone your current working OS and Avid software. Just clone that drive to another drive…cheap external. This is a backup of your working system. THEN upgrade. If things go south in ANY way, you can always recover from the backup.
    Shane
    Little Frog Post
  • Dan Crouch
    May 15, 2014 at 8:20 pm
    Thanks for the post Shane.
    Is that simply apple C my hard drive and copy it on to an external drive?
    Or should I use a program, time machine or something?
    Cheers,
    Dan.
  • Dan Crouch
    May 15, 2014 at 8:41 pm
    Thanks Graham, hadn’t thought of that.
    Dan.
  • Glenn Sakatch
    May 16, 2014 at 1:35 pm
    if you are on version 3 now, wouldn’t you be on a dongle?
    Glenn
  • Dan Crouch
    May 17, 2014 at 11:19 am
    Thanks for post’s guys.
    After two scary crashes the upgrade worked fine and my version 3
    timelines opened up and played perfectly.
    Thanks again for all your post’s.
    Cheers,
    Dan.
