Activity › Forums › Apple Final Cut Pro Legacy › upgraded to FCP6 clips not in synch??
  • upgraded to FCP6 clips not in synch??
    Posted by Spencer Schilly on June 7, 2007 at 3:19 pm
    I recently upgraded to fcp6.
    several of my clips are not in synch in one of my projects
    I’m working in a 23.98 timeline and the clips in question are 23.98 clips as well.
    when I play the quicktime file they are fine, but in FCP they are not.
    Looks like the clips start off in synch then lose it… badly.
    Spencer Schilly replied 19 years, 3 months ago 4 Members · 5 Replies
  • Chris Poisson
    June 7, 2007 at 4:07 pm
    If this is an old project from before your upgrade, I would create a brand new project, make sure the easy setup matches your workflow and copy and paste everything from your old project’s browser and timeline. If you still have sync issues, try trashing prefs, toss all your old render files and re-render, restart everything or all three.
  • Mark Maness
    June 7, 2007 at 8:34 pm
    Before I’d go that far… I just create a new sequence, copy and paste your old sequence into it.
    If that doesn’t work, copy all of your stuff from your old project to a new one.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Spencer Schilly
    June 8, 2007 at 12:45 pm
    I’ve tried all of the above – except trashing the preferences… where do i do that??
    the weird thing is – after i trash all the render files it’s not asking me to render anything!?!? There are no red lines. the footage in question is sped up and i don’t understand why??
  • Keith Golinski
    June 8, 2007 at 1:06 pm
    I had the same thing happening to footage that I imported. It only happened to one clip on one of my projects an to 3 clips from anohter. It’s completely random. I’ve found that if I bring the clips in question into the cinema tools app and tell it to conform the clips to 23.98, even to though in the analyze clip window it says the clips already are 23.98 I did it anyway. When I re-opened the project the clips in question went off-line and then reconnected on their own and worked perfect. Something in the cinema tools resets the clips to act correctly in the timeline. This is one of two upgrade glitiches that I’m sure they will fix in upcoming updates. Upgrading is all about the work arounds until they fix all the updates. Good luck. Hope this helps.
    -Keith
    FULVEW.com
  • Spencer Schilly
    June 8, 2007 at 1:20 pm
    THAT WORKED!!! Thank you!!!
    Still weird that render options are showing up…
