Activity Forums VEGAS Pro Upgraded PC with stuttering playback.
  • Upgraded PC with stuttering playback.
    Posted by Paul Gregory on December 20, 2011 at 4:29 am
    I have just upgraded my PC & done a clean reinstall on Windows 7 64 bit as well as swithing to version 11 at the same time. I’m running a i7 920 processor with 12 GB of ram.
    I’m finding that playing from the timeline using Vegas pro 11 results in stuttering playback & sometimes it only previews about 9 fps even when preview window is set to 1/4. The same clips will play without a problem using WMP or other players on the machine.
    Checking the properties of a clip it tells me that it’s AVC 1920×1080 upper field first.
    I have a gaggit on the desktop & it tells me when the PC’c processor cores are working hard nut theie not. The only otherc thing that I can think of is that I accidently changed opacity etc for the entite timeline, but I don’t think that this is the case.
    Any other ideas? Incidently this is the first time using Version 11. As far as I can see we were better of with the stabilized that was in version 10.
    Thanks in advance
    Paul Gregory replied 14 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
