Activity › Forums › Apple Final Cut Pro Legacy › Upgrade to FCP6 and Quad 3.2 with Kona SD?
Posted by Paul Harb on February 22, 2008 at 11:24 pmSo I finally, and I stress finally upgraded my powermac today. I have been using a dual 2.0, powerPC, 4gig, with a Huge SCSI Raid and the old KonaSD card. My questions are these.
Will the KonaSD card work in the newer PCI Express slots?
Will the UL4D SCSI card work?Just wondering what will still work as I unpack this computer today….and what expensive stuff…ie..RAID, or capture card, do I NEED to replace. If I dont NEED to do uncompressed HD at this time, do will this stuff just work with newer drivers?
I know thats a lot, anyone going through this or with any info to make this less painful would be appreciated greatly. Thanks.
Paul Harb-Director/Editor
Wrong Beach MultimediaRobert Leong replied 18 years, 6 months ago 5 Members · 8 Replies -
Walter Biscardi
February 23, 2008 at 2:55 am[Paul Harb] “Will the KonaSD card work in the newer PCI Express slots?”
No.
[Paul Harb] “Will the UL4D SCSI card work?”
No
[Paul Harb] “I know thats a lot, anyone going through this or with any info to make this less painful would be appreciated greatly. Thanks.”
No internal cards from the PCI-X machines will work in the new PCIe machines. I would suggest you at least get a Kona LHe so you can continue to edit SD, but you’re ready for HD.
The big difference between that and the Kona 3 is you can’t up-convert SD to HD with the LHe, but other than that, you’ll get the same performance as your SD.
No clue on the SCSI card and if there are any that work in PCIe machines. Haven’t used SCSI in about two years or so.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Shane Ross
February 23, 2008 at 2:56 am[Paul Harb] “Will the KonaSD card work in the newer PCI Express slots?”
No. The old PowerMac had PCI-x slots. The new ones tout PCIe. It won’t work.
I think not…for the same reason. PCI-X vs PCIe.
[Paul Harb] “and what expensive stuff…ie..RAID, or capture card, do I NEED to replace. If I dont NEED to do uncompressed HD at this time, do will this stuff just work with newer drivers?”
This is why I avoided upgrading for a while. Because I have a Dual 2Ghz G5 with eSATA Raid and Kona LH…and so getting the new machine means new machine, new capture card, new RAID card…
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.LFHD.net
Read my blog! -
Martial Bachoffner
February 23, 2008 at 6:46 amThe UL5D is for PCI-e.
Regards,
MartialVancouver Island Final Cut Pro User Group
Martial Bachoffner
Founder and Administrator -
Paul Harb
February 23, 2008 at 6:31 pmYa thats what I figured…..Ive been hired for the past 2 years on jobs that pay for the systems, which is the norm for feature films…..but I am ready to upgrade everything for HD online.
Kona 3 is a no brainer for me……no anyone selling one? 😉
Also I noticed your using Max Digital, good results? I have always like Huge, now Ciprico…but the Max Digitals Ive been hearing about…..thoughts?
Thks.
Paul
Wrong Beach Multimedia -
Paul Harb
February 23, 2008 at 6:45 pmOne other question, should I be getting the Kona 3 x? if Im running it on the new Quad 3.2? The only card in it right now is the NiVidia 8800 I think it is….
Paul
Walter Biscardi
February 24, 2008 at 3:28 pm[Paul Harb] “Also I noticed your using Max Digital, good results? I have always like Huge, now Ciprico…but the Max Digitals Ive been hearing about…..thoughts?”
We tested MaxxDigital, Dulce and Sonnet after three CalDigits in a row went south in a span of 6 months. I purchased two 8TB EVO HD units from MaxxDigital which top out at 500MB/s in RAID 5. So yeah, we’re VERY happy with them and the tech support we’ve been getting from both Maxx and ATTO.
Walter Biscardi
February 24, 2008 at 3:30 pm[Paul Harb] “One other question, should I be getting the Kona 3 x?”
No, that’s the older PCI-X version of the card. Kona 3 is for the new PCI-e machines.
[Paul Harb] “The only card in it right now is the NiVidia 8800 I think it is….”
The machines come standard with the ATI 2600. If the nVidia is in your specs, then you changed the card.
Robert Leong
February 25, 2008 at 5:01 pm[Paul Harb] “do I NEED to replace.”
Hi Paul, you can extend the usefulness of the G5 with our Quad / Duo Quad RAID protected SATA setup. Option of PCI-x will run in the classic PowerPC and PCI-e also available for the new Mac Pro.
Robert Leong / Dulce Tech Support
