Activity › Forums › Adobe After Effects › upgrade the ram and the memory may cause a problem?
  • upgrade the ram and the memory may cause a problem?
    Posted by Gerardo Flores on May 5, 2010 at 6:17 pm
    Hello guys
    Last week I have upgrade the ram of my macbook pro
    + change the hard disk ( from 200 to 400 GB)
    The PC guy just save all (programs even) file on my old hard disk to the new one…
    now I am working with a new hard disk with my all files and programs
    After that Im trying to render a video with After effects and
    I have all the time error in second 17 or sometimes later…
    Can this changes on the machine couse those problems?
    Or maybe is the fact that Im using too much ( I mean a lot ) of
    effects with particule matrix form noise industries?
    Thank you for your comments…
    I already have lost a week with this…
    + rendering is taking a huge time 🙁
    Im really dissapointed now.
    Best Regards.
    Gerardo
    Thats my real name 🙂
    Walter Soyka replied 16 years, 4 months ago 3 Members · 5 Replies
  • Jeffrey Kaplan
    May 5, 2010 at 7:17 pm
    What are you trying to render out a movie (compressed?) or image sequence?
    Jeff Kaplan
    Point 360 WEST
    Animation & VFX Department
    http://www.point360west.com
  • Gerardo Flores
    May 5, 2010 at 7:29 pm
    Hi Jeffrey
    Thank you for ask
    Im triying to render a image sequence something like this one…
  • Jeffrey Kaplan
    May 5, 2010 at 7:39 pm
    Can’t you just pick up the render from where the error happened and combine the two image sequences? That is generally the advantage of rendering an image sequence.
    Jeff Kaplan
    Point 360 WEST
  • Gerardo Flores
    May 5, 2010 at 8:26 pm
    To say the true I will like to have the entired video
    to make the compresion at the end…
    anyway.
    After effects doent alow me to do that…
    I must start again…
    What do you think can cause this problem Jeffrey?
    Thank you for the comments
  • Walter Soyka
    May 5, 2010 at 8:35 pm
    When you render your comp, choose “Multimachine Sequence” as your Output Module. If the render fails, just add the re-render the comp; Multimachine Sequence will automatically skip existing frames.
    If you use any other kind of image sequence, you must check the “Skip existing frames” button in the Output Module settings.
    If you use any Output Module that creates a movie, you will not be able to resume where it failed.
    Walter Soyka
