Activity Forums Apple Final Cut Pro Legacy upgrade problems
  • upgrade problems
    Posted by Postproman on August 25, 2005 at 1:39 pm
    Hi all-
    I just upgraded our production suite (fcp 5 from 4.5) and everything seems to have slowed down a bit. FCP drops frames much more often. Waveforms in the timeline take forever to build. It’s just not as responsive as it was. Motion isn’t realtime anymore. I also upgraded to Tiger before the suite.
    What did I do wrong? Can I fix this anoying problem.
    THANKS!
    System: Tiger – dual 2.5 – 4 gigs – Huge Systems U320 1tb
    Tony! Hulette replied 21 years, 1 month ago 2 Members · 1 Reply
  • Tony! Hulette
    August 25, 2005 at 10:41 pm
    Repair your permissions, delete your FCP & Motion preferences and cache’s. Repair your the drives using DiskWarror (or at least Disk Utility). Check to make sure you have the latest firmware, drivers, etc for all your video hardware (video card, RAID, etc). Make sure you have downloaded any updates to software applications as needed.
    Tony!
