Activity Forums Apple Final Cut Pro Legacy Upgrade potential drama?
  • Upgrade potential drama?
    Posted by Charlie Kosheff on March 11, 2010 at 1:30 pm
    I would never do this mid-project, but I need to upgrade to 6 from 5 because my deliverable has changed to ProRes. I know there has been some drama in the past about this, but so far I have only one project in progress, which is all P2 DVCPro HD imports. I have done no effects or color correction or speed changes. Just a few cuts-only sequences from interviews. There is probably 3-4 hours of footage in there now.
    Can I get away with this? I’ll save a 5.14 version my project first…
    if so then I’ll only be one version behind on FCP!
    PS can’t use version 7- no MacPro.
    Michael Gissing replied 16 years, 6 months ago 4 Members · 3 Replies
  • Jaap Van hoewijk
    March 11, 2010 at 2:29 pm
    you could do a clean install of system and FCP 6 on another internal drive, or FW drive. This way you can easily see if it works to open the project file of your FCP 5 into FCP 6. If not, try an XML export and import that into FCP 6. And you’ll still have your old system and FCP 5 as a backup..
    good luck!
  • Chris Tompkins
    March 11, 2010 at 3:23 pm
    I would output an EDL or XML file.
    Chris Tompkins
    Video Atlanta
  • Michael Gissing
    March 11, 2010 at 10:00 pm
    Search this forum about how to do an upgrade. It has been covered here many times and the resounding advice is a clean install of OS and FCS on a new drive, keeping the old drive as an alt boot so you can boot either.
