Activity › Forums › Apple Final Cut Pro Legacy › Upgrade on a G5
Upgrade on a G5
Posted by Stewart Stroup on July 17, 2008 at 9:59 pmI’m getting conflicting information regarding upgrading from FCP 5 to FCP Studio 2. I’m working with a PowerPC G5 with 4×2.5Ghz processors. OSX 10.4.11. Some folks tell me that FCP 2 must be on an Intel machine to function properly, while others say that FCP 2 is Universal and will work just fine on the G5. What’s the real story? Any help would be appreciated!
Miodrag Ristic replied 18 years, 1 month ago 6 Members · 7 Replies -
Walter Biscardi
July 17, 2008 at 10:05 pmWrong, it’s universal works equally well on both.
We just retired a G5 Dual 2.0 three weeks ago and it was running Studio 2 just fine. We’re currently running a G5 Quad 2.5 in our third suite and it runs Studio 2 just fine.
[Stewart Stroup] “Some folks tell me that FCP 2 must be on an Intel machine to function properly”
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Chris Poisson
July 17, 2008 at 10:05 pmIt works just fine on non-Intel machines.
Have a wonderful day.
Mark Landman
July 17, 2008 at 11:26 pmI’m running Studio 2 on a Dual 2.0 G5 and it runs fine.
Mark Landman
PM Productions
Champaign, IL -
Baz Leffler
July 19, 2008 at 3:25 amI too have Studio 2 on a Dual 2.0 G5 (2.5 gig RAM) and it is running fine.
In fact I have put a Decklink HD Pro PCIe card in it with a 2 drive external Sata raid connected to an internal PCIe controller and am able to capture and playback HDCAM no problems – even though the machine is under spec! The only down side is that it takes much longer to render stuff than my Octo core Mac Pro but hey! it was only designed as a capture/playback box (but now does a lot more).As an ex PC user who dates back to the late 70’s playing with CPM I really am converted now. But back then I did own an Apple II and was a full blown Aussie hippie (never murdered anyone though…)
Baz
What would I do without the ‘UNDO’ button!!!!
Miodrag Ristic
July 20, 2008 at 11:08 amHey Baz,
I’ve got a similar Mac (G5 Dual 2.3 with 2 GB memory, GeForce 6600, FCStudio) and wanting to set up
for HD(V) and I’m not very confident with those PCI cards and everything involved.Problem is, I’m not even sure what cards are compatible with my machine (in About This Mac,
under PCI it says only PCI, so is it “x” or “e”, I don’t know). Manual says it’s PCIe,
it’s a last G5 series, medium strength configuration.Living in Geelong, we don’t have a great support here, so, did you do it yourself
or where did you have it all installed (Decklink, hard drives, etc).
I need someone who is going to advise me on the upgrade path.Would you be able to point to right direction, in terms of who did it for you,
they might be in Melbourne if I was lucky.Cheers
Mio
Baz Leffler
July 21, 2008 at 12:35 amhey Mio
Sorry but I did it all myself. I am an extreme experimenter and never take someone’s word for what can and can’t be done; I try it for myself.
You should download ‘Mactracker’ to determine your Macs setup. But if it is a PCIe version then you would be in the same situation and my Pcie G5 so it would be good to go.
I also have a slightly older mac that doesn’t even have PciX slots; just PCI and I tried a Decklink HD Pro PciX card in it and it worked ok for SD but would not work at all in HD so there are Mac’s and there are Mac’s….
But remember I come with no guarantees so don’t hold me to it.
Baz
Miodrag Ristic
July 21, 2008 at 12:57 amThanks Baz,
I’ll start from Macktrecker then.
Oh yes, I visited your website,
pretty impressive set-up.Cheers
Mio
