Activity Forums VEGAS Pro Upgrade my Windows 7 – Vegas 10.0 Editing Machine
  • Upgrade my Windows 7 – Vegas 10.0 Editing Machine
    Posted by Geoff Chandler on February 7, 2017 at 7:38 pm
    I have to take my editing computer in and have a bigger SSD boot drive installed and while it’s there I thought I might have them upgrade the processor and/or graphics card if it would help editing performance. Rendering speed is not a big deal but smooth editing performance is probably the issue that I’d like improved if possible with any bolt-on upgrades.
    I shoot weddings with Panasonic GH3s, GH4s and soon GH5. The recording codec is MOV 1920×1080 24p 72 Mbps All-Intra but I may do some shooting in 4K this 2017 season.
    My desktop is currently configured as followed:
    Intel Core i7-3770 CPU @ 3.40GHz
    16 GB RAM
    Nvdia GeForce GGTX 660
    Windows 7 – 64-bit
    Vegas 10.0
    Thanks for your suggestions!
    Geoffrey
    https://www.chandlervideo.com
    Geoff Chandler replied 9 years, 7 months ago 6 Members · 14 Replies
  • 14 Replies
  • Steve Rhoden
    February 7, 2017 at 10:41 pm
    I’m not seeing your question, or what specifically you want suggestion on!
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Geoff Chandler
    February 7, 2017 at 10:49 pm
    Looking at my current setup, I’m wondering if a processor or graphics card upgrade would increase playback smoothness on the timeline. I think that sums up my question.
    Thanks.
  • Paul Berk
    February 8, 2017 at 4:20 am
    Yes. CPU upgrade will help smooth playback …. Always best to get as fast a CPU as you can afford.
  • Ole Kristiansen
    February 8, 2017 at 8:11 am
    Yes, update Motherboard, cpu, gpu, ram and Vegas !
    Why .mov with Vegas ?
  • Geoff Chandler
    February 8, 2017 at 12:56 pm
    Why MOV?
    My choices with a Panasonic GH3 are:
    AVCHD 24p @ 24Mbps
    MP4 30p @ 20Mbps
    MOV 24p @ 72Mbps ALL-Intra
    I was under the impression I would get a higher quality image from the higher bit rate. If nothing else, have more room to tweak exposure and color. When selecting MOV in the camera, a warning comes up that reads, “A high performance PC is required to play or edit. Proceed?” I’ve never done tests with the other codec options but the 72Mbps is the setting everyone was crazy about when the camera first came out.
    Is there a transcoding option or recommendation to make editing and playback smoother?
  • Ole Kristiansen
    February 8, 2017 at 1:12 pm
    Hi Geoff
    Vegas and .mov is not the best combination because .mov use Apple 32bit decoder !
    “Is there a transcoding option or recommendation to make editing and playback smoother?”
    Yes, Cineform – If you install the free Gopro Studio – you can use Cineform in Vegas !
  • Geoff Chandler
    February 8, 2017 at 2:24 pm
    I installed GoPro Studio and quickly figured out how to convert files. They play back smoothly however the converted file has no audio clip associated with it when I open in my Vegas timeline.
  • Ole Kristiansen
    February 8, 2017 at 3:18 pm
    Hi Geoff
    You can try Batch Render your clips to Cineform in Vegas !
    I think you first have to make a Cineform template – save and re-open Vegas to see the new template in the Batch Render window !
    I made a simple guide !
    https://www.youtube.com/watch?v=vo095lPxgLI
  • Aaron Star
    February 8, 2017 at 3:26 pm
    “Intel Core i7-3770 CPU @ 3.40GHz
    16 GB RAM
    Windows 7 – 64-bit
    Vegas 10.0”
    The “x”77 series chipset (i7-3770) was a good rig at one point. Assuming you have that chipset. Upgrades are going to not do a whole lot unless you are running really slow RAM and no SSD. That chipset was the end of PCIe2.0, and the next generation came with PCIe3.0. 3.0 has not only improved bandwidth, but also comes with less overhead for even more bandwidth. Your GPU will appreciate the 3.0 improvements.
    GPU upgrade, you could go up to an RX480, 390x, or Fury-x. This would work much better with Vegas.
    16GB of ram is good, but you want to make sure you have not fully populated the DIMM slots. If your board has dual channel, that means work 16-32Gb of ram out of 2 sticks of memory. Adding more will cause most motherboards to drop back to single channel operation. Memory bandwidth is very important to Vegas, encoding, and general operation. Test your memory bandwidth with Winsat mem, or memtest86+.
    Windows 10 pro has a much improved memory controller. I recommend moving to Win10-64.
    Motherboard design type could matter with regards to SSD SATA drives. Try and get an M2 slot NVME Samsung 950 Pro. With SSD drives you are placing a lot of load on the DMI bridge. Look up DMI bridge. So a motherboard like the x99 will give you more options for high bandwidth devices like SSDs.
    Z270 chipset with the latest processor would be a good upgrade choice for a modest configuration. This would upgrade you to PCIe3.0, and DD4 memory the latest evolution. Also the CPU would give you the longest service life since it comes with the most contemporary instruction sets. X99 still has more memory bandwidth, but the memory controller speeds of the z270 are reaching a point where they are almost neck and neck these days. We are still waiting on an x99 class motherboard for the latest generation of CPUs.
    I would upgrade to VP 14, as 10 is not going to take advantage of any GPU upgrades.
    Vegas may work just fine with the .MOV encoded material. Try VP14 with that format, .MOV may not use QT and may use native mode of operation for certain codecs like Prores and AVC. You can determine this by looking at what .dll is being used under the Vegas media properties. That format sounds alot like XAVC-intra in a .MOV container. FFMPEG may be able to re-wrap without re-encode, if you have a problem with playback.
  • Geoff Chandler
    February 8, 2017 at 3:48 pm
    Thanks. But a typical wedding has hundreds of clips. Is the workflow you’re demonstrating requiring putting all the clips on the timeline to convert (transcode)?
