Activity › Forums › VEGAS Pro › Upgrade from V 8 to V 10 Install Problems
  • Upgrade from V 8 to V 10 Install Problems
    Posted by Dennis Tully on May 1, 2011 at 5:12 pm
    I had Vegas Versions 8 and 10 on my PC. I decided to remove Ver 8. Then Problems. Could not find Ver 10 at all. I downloaded Ver 10 from Sony again but when I ran the Install exe. it said It detected an earlier version and do I wish to update to ver. 10? I said yes and it said to put disc in my cd-rom drive.
    Don’t have a disc, just the downloaded software ver. 10.
    It also says “Error: 1612 occured during installation.
    Anyone Help, please.
    Dennis Tully replied 15 years, 4 months ago 2 Members · 2 Replies
  • Dave Lozinski
    May 2, 2011 at 12:36 am
    I’ve had this happen before too with different versions of Vegas.
    There’s probably some left over Registry entries and/or folders/files on your drive.
    I’m not sure how computer savy you are, but I would try a complete removal of both, reboot, and then just reinstall Vegas 10.
    If that doesn’t work, what I had to do (with another software package, not Vegas) is download Revo Uninstaller Pro:
    https://www.revouninstallerpro.com
    as that scans for and removes left over registry entries and files.
    So if you have to go that route, reinstall Vegas Pro 8, then use Revo Uninstaller to remove everything, reboot, then try installing Vegas Pro 10.
    Hope this helps.
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
  • Dennis Tully
    May 3, 2011 at 12:26 pm
    As a follow-up, I completely uninstalled both 8 & 10.
    Ran Windows Install Cleanup, Ran Registry Cleaner, Re-Booted.
    Now when I run the Version 10 install program, I get this new error message:
    ERROR: 1625 occured during installation
    I am running Windows 7 Home.
    Anyone?
