Activity › Forums › AJA Video Systems › upgrade firmware 2.0?
  • upgrade firmware 2.0?
    Posted by Kim Rowley on December 9, 2010 at 8:42 am
    Just purchased Ki-Pro to record conferences through 2 different vision mixers. I have done this for 4 jobs to date (tried both component and SDI SD settings) and so far so good. The thread about the Ki-Pro stopping a few threads back spooked me and though personally I’ve had no trouble I am afraid to upgrade the firmware to 2.0. Should I be? Part of me says to leave well enough alone… Can somebody play Daddy and tell me it will be OK?
    Dual 3 GHz Dual Core Intel, 4GB RAM, ATI Radeon X1900, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP Studio 2 (6.0.6), OS X10.4.11
    Marc Colemont replied 15 years, 9 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    December 9, 2010 at 3:38 pm
    The KiPro works the same in that regard in v1 or v2. If it doesn’t like the signal, it stops.
    So, you’ll be ok, just send a robust signal.
  • Kim Rowley
    December 9, 2010 at 6:45 pm
    Thanks Jeremy. I thought so. It’s just nice to hear it said. All the best
  • Marc Colemont
    December 13, 2010 at 1:23 pm
    From a AJA tech support guy I also got the reply that the version 2.0 is a bit more forgiving for the signal input then version 1.1.
