Activity Forums Apple Final Cut Pro Legacy Upgrade 4.5 to 5
  • Upgrade 4.5 to 5
    Posted by David Johnson on August 30, 2005 at 4:04 am
    I’ll need to upgrade from FCP 4.5 to 5 (and Tiger) soon and am very concerned about project compatability and folder structure issues since projects never die in my environment (commonly need to revisit projects from a year or more ago). Any suggestions?
    David Johnson replied 21 years ago 4 Members · 4 Replies
  • Shane Ross
    August 30, 2005 at 4:27 am
    The upgrade should be pretty painless, but a good way to keep FCP 4.5 and Panther around (A DARN stable system if you ask me) is to install Panther and FCP 4.5 on a separate drive and boot from that drive when you need to. Or, if you don’t have another secondary internal yet, get one and install Tiger and FCP 5 on that and keep you old system on the original drive.
    That is what I do.
  • Jeff Carpenter
    August 30, 2005 at 4:54 am
    I’ve had no problems at all opening 4.5 projects into 5.0
    Just remember that you can’t go BACK once you’ve done that. It might be a good idea to make a duplicate copy of anything you’re going to open in 5 so that you have an un-changed legacy file.
    But that’s just for safety. I’ve had no problems with old projects on FCP 5.
  • Dan Riley
    August 30, 2005 at 6:07 am
    I HAVE had problems opening 4.5 project in 5.
    Some do, and convert just fine. Others won’t
    open at all. They crash midway through the process.
    I kept my 4.5/OS 10.3.7. system on a separate drive
    partition because I was expecting trouble. I did a clean
    install of Tiger and then Final Cut Studio. Now if I
    need to go back to the old 4.5 project, I just boot
    into that other partition, open FCP 4.5 and the old
    project file and everything is fine. I’ve updated my
    Aurora Pipe Studio drivers on the old partition too.
    They are backwords compatible so I was told
    that was the way to go. It’s been good.
    FCP5, well that’s another story.
    I would not have upgraded except I needed the
    multicam for a project because our AVID was
    tied up. FCP 5 is not ready for prime time if
    you are doing a lower rez offline, like DV, then
    uprezing to 10 bit uncompressed for finishing.
    The media management is terrible.
    Many extra hours will be spent by you fixing stuff.
    I’m pretty frustrated with FCP 5 (and 5.0.2)
    because of this and a general instability
    compared to 4.5, which was very solid.
    But the multicam did work very well for my 4 camera shoot.
    I’m used to AVID so that says something
    for Apple’s 1.0 version of that feature.
    Dan
  • David Johnson
    August 30, 2005 at 7:59 pm
    Thanks much to each of you for the useful info/warnings. I’ve heard of similar issues with 5 and am also trying to decide whether I should stick with FCP for the second system/suite we’re about to build or go with one of the comparable Avid systems (coming from PC world, I have little experience with either, although plenty with other NLEs). Any insight/comparisons from those who’ve used both extensively?
