Activity Forums Creative Community Conversations upgrade 10.0.4 ???
  • Aindreas Gallagher
    April 10, 2012 at 11:52 pm
    tl;dr
    It all rocks, Apple remaking the world, FCPX is nuclear fusion – i propose the motion and if you don’t like it don’t read it…
    ahemmm.
    https://vimeo.com/user1590967/videos
    http://www.ogallchoir.net
    promo producer/editor.grading/motion graphics
  • Andrew Kimery
    April 11, 2012 at 12:14 am
    [Craig Seeman]
    Just to be clear, my stretched tangent is that the $3000 Power Box becomes a $5000 purchase given the two Thunderbolt monitors needed/desired. It’s part of my thinking in how Apple might make the Power Box into something a bit more viable for them as far as locking the creative pro into an Apple ecosystem.”
    I didn’t read the whole thread so apologies if I missed something vital, but I don’t see how you get locked into Apple’s monitors since ThB isn’t Apple exclusive and ThB doubles as a Display Port.
    -Andrew
    2.9 GHz 8-core (4,1), FCP 7.0.3, 10.6.6
    Blackmagic Multibridge Eclipse (7.9.5)
  • Craig Seeman
    April 11, 2012 at 12:23 am
    [Andrew Kimery] “I didn’t read the whole thread so apologies if I missed something vital, but I don’t see how you get locked into Apple’s monitors since ThB isn’t Apple exclusive “
    So far, the only Thunderbolt monitor I know of is Apple’s.
    Stick a display port monitor in there and you’ve lost the pass through.
  • Andrew Kimery
    April 11, 2012 at 12:44 am
    [Craig Seeman] “So far, the only Thunderbolt monitor I know of is Apple’s.
    Stick a display port monitor in there and you’ve lost the pass through.”
    Since non-Apple computers are just now coming out w/ThB I’m sure it will take a year or so for non-Apple monitors to get to market.
    As long as display port terminates the loop I thought it could be ThB up until that point. So you couldn’t loop thru a monitor using display port but you could end at a monitor using display port.
    -Andrew
  • Craig Seeman
    April 11, 2012 at 1:32 am
    [Andrew Kimery] “Since non-Apple computers are just now coming out w/ThB I’m sure it will take a year or so for non-Apple monitors to get to market.”
    I’d expect so too. We’ll have to see what happens as Acer, Asus, Lenovo bring their Thunderbolt computers to market.
    [Andrew Kimery] “As long as display port terminates the loop I thought it could be ThB up until that point. So you couldn’t loop thru a monitor using display port but you could end at a monitor using display port.”
    The only obvious problem would be the inconvenience having to disconnect the monitor if there were things in front of it in the chain you wanted to remove. There’s also the issue of many TB devices not having pass through so in many cases that’s not possible such as with Blackmagic or Matrox Video I/O. AJA IO XT has pass through.
  • Oliver Peters
    April 11, 2012 at 1:46 am
    [Neil Goodman] “6.0.1 is the last update from Avid, and if there own forums are any indication its not 100 percent stable, id say more like 75 percent if that. “
    All I can say is that I’m running FCP X and Symphony 6.0.1 and the Avid software is way more stable and reliable than FCP X at this point. I am running both in software-only configurations.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Andrew Kimery
    April 11, 2012 at 1:56 am
    [Craig Seeman] “The only obvious problem would be the inconvenience having to disconnect the monitor if there were things in front of it in the chain you wanted to remove. There’s also the issue of many TB devices not having pass through so in many cases that’s not possible such as with Blackmagic or Matrox Video I/O. AJA IO XT has pass through.”
    Agreed. Multiple ThB ports would make sense on all of Apple’s computers (w/the exception of the Air). Bye-bye FW800?
    -Andrew
  • Bill Davis
    April 11, 2012 at 2:33 am
    Doesn’t that LaCie hub kinda solve this?
    If you have a one to many hub, how important is loop through any more?
    Granted, it requires power, but at such low levels, that I can’t believe that the market won’t enable a battery powered hub that can do this.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • Chris Harlan
    April 11, 2012 at 6:29 am
    [Bill Davis] “Doesn’t that LaCie hub kinda solve this?
    The LaCie TBolt hub is for eSATA devices. TBolt can’t be split by a hub. It needs a single line like SCSI.
Page 5 of 5
