Activity Forums Apple Final Cut Pro Legacy upgarding to HD. Help with options
  • upgarding to HD. Help with options
    Posted by Rick Neely on November 17, 2006 at 11:28 pm
    Hi guys,
    Have been asked by a client to research upgrading their current FCP system to handle High Def video. Here’s what they have:
    Mac Quad G5 with standard NVIDIA Graphics card (I think it was acquired a year ago)
    AJA IO
    Final Cut Studio 5.1
    Macgurus Hot Swappable burly rack SATA storage racks connected va PCI-X host card
    The plan is to maintain as much of what they have while upgrading to allow the ability to fully handle HDV and especially DVCPRO HD (50 & 100). I don’t think they will explore HDCam.
    My thinking is they add an AJA Kona LS card with matching breakout box and increase the Hard drive space and maybe add a bit more computer Ram. Is my thinking at least close or even dead on? Should I recommend an upgrade of the internal graphics card as well?
    Questions of concern?
    what about the SATA Hard drives? Will data transfer be fast enough for DVCPRO HD 4:2:2 or will I have to upgrade to SCSI connection or even (gasp) recommend an Xserve?
    The Quad G5 does not have Intel chips I believe. Do they need to be?
    Does the breakoutbox do anymore than provide convenience in plugging in decks and control?
    Any advice on this would be great. Thanks again!!
    Rick
    Tom Meegan replied 19 years, 10 months ago 5 Members · 4 Replies
  • Aaron Neitz
    November 17, 2006 at 11:37 pm
    You won’t need the Io – but you could use it as a SD converter box (SDI to composite, s-video, etc…)
    The Kona card will work just fine. Plus it also does SD.
    You could use FW drives for DVCPRO-HD or HDV. The throughput isn’t very high. Only when you get into uncompressed HD do you need mad speed.
    Go with at least 2.5 gigs of RAM, but 4 would be great (FCP maxes at 2.5, and that’ll give you extra RAM for swapping applications).
    The Nvidia card is totally fine.
  • David Roth weiss
    November 18, 2006 at 1:12 am
    [Rick Neely] “what about the SATA Hard drives? Will data transfer be fast enough for DVCPRO HD 4:2:2 or will I have to upgrade to SCSI connection or even (gasp) recommend an Xserve?”
    Your SATA drive array has all the throughput you need if the drives are striped.
    DRW
  • Walter Biscardi
    November 18, 2006 at 1:28 am
    [Rick Neely] “Questions of concern?
    You can cut DVCPro HD with FW800 drives.
    [Rick Neely] “My thinking is they add an AJA Kona LS card with matching breakout box and increase the Hard drive space and maybe add a bit more computer Ram. Is my thinking at least close or even dead on? Should I recommend an upgrade of the internal graphics card as well?”
    Kona LS is standard def only, you want a Kona LH or Kona 2 for your machine.
    [Rick Neely] “The Quad G5 does not have Intel chips I believe. Do they need to be?”
    Nope, but know that the Kona 2 and LH will NOT transfer into an Intel box in the future. Different architecture.
    [Rick Neely] “Does the breakoutbox do anymore than provide convenience in plugging in decks and control?”
    For $300 the breakout box is MUCH better than the long snake of cables you get with the card. Get the BOB.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Tom Meegan
    November 21, 2006 at 11:52 am
    I’m seconding Walter on the break out box. It will handle wear and tear better, deals with longer cable runs, and presents a more professional appearance. Everytime you don’t have to crawl under a desk with a flash light to make a cable swap, you will feel good about the purchase.
    Tom
