Activity › Forums › Adobe Premiere Pro › Updating Timeline. Please wait….
  • Updating Timeline. Please wait….
    Posted by Jeff Symms on May 13, 2006 at 12:48 am
    Hello all
    I have seen other people with this problem, but have yet to see an answear.I am working on a montage.
    I am using Premiere Pro 1.5.1 and Matrox rtx100e. I am using all .tga files (720 x 480 from photoshop)and a couple of video clips captured from vhs.
    I have hotfix2 installed.
    Everything was going along fine untill suddenly I get:
    “Updating Timeline. Please wait….” I waited for hours.
    I have turned off the PC, waited a few hours and turned it back on. When I try to do ANYTHING, I get the message again. I don’t get it..I have done many projects with this set up.
    My first thought is it has something to do with Matrox (I have had problems with Matrox in the past). I looked in their forums, and though I did see similar problems, I saw no solution. I have searched the forums here with the same result. I have put many hours into this project and the client would like to know “how far along I am”. I am at the point of desperation. I can’t see starting this project over.
    Can anyone PLEASE help?? – PLEASE!-
    Thanks in advance for a quick response !
    Jeff
    Craig Howard replied 20 years, 4 months ago 5 Members · 11 Replies
  • 11 Replies
  • Xavier De champs
    May 13, 2006 at 10:24 am
    Hi, I googles a bit, and found this forum. They mentioned something about a patch or something, but I don
  • Erik Pontius
    May 13, 2006 at 2:29 pm
    As a test you mnight also try starting a completely new project with the same settings, etc. Then importing your old project into this new one.
  • Jeff Symms
    May 13, 2006 at 4:03 pm
    Thanks Kovboy.
    I still do not know why this happened. However, I opened the project, took out a .tga file,and saved the project with a different name. It now appears ok….at least til the next time.
    I would very much like to know how to avoid this in the future tho.
    -J
  • Craig Howard
    May 13, 2006 at 9:46 pm
    Jeff – I am convinced this is a Matrox issue and I worked long and hard to get the answers to the “curse”. I never saw it again once I dumped the card from my NLE and I am totally happy with the performance and stability of PremPro 2 sans Matrox.
    BTW: I was able to improve the Matrox stability with a large number of tweaks but never got 100%
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Jeff Symms
    May 13, 2006 at 11:14 pm
    Ahh wonderful…it is happening yet again….anyone got ideas??
  • Jeff Symms
    May 13, 2006 at 11:16 pm
    I have done this , but now the project looks like one big .avi file. Therefore I can not change anything.
  • Jeff Symms
    May 13, 2006 at 11:18 pm
    Thanks for the reply. My thought is that it is also Matrox. They have yet to help me with this problem. I would not recomend Matrox to anyone. Too bad I lost all that money buying thier product…perhaps a class action suit is in order…?
  • Craig Howard
    May 14, 2006 at 2:54 am
    Dump the card is my suggestion and move your project into a Non Matrox PremPro 2 Project. (It will be worth the effort and you will sleep better).
    Craig Howard
    Auckland
    New Zealand
  • Aanarav Sareen
    May 15, 2006 at 2:22 pm
    It’s definitely the card. This was an issue even with Premiere Pro 1.0 and the Matrox card.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Jeff Symms
    May 15, 2006 at 6:42 pm
    Yes…so what is the solution?
