Activity Forums Avid Media Composer Updating QT to QT 7.0
  • Updating QT to QT 7.0
    Posted by Jimbow on July 31, 2006 at 3:19 pm
    I am looking to update QT on some of my computers and am worried that a newer version may cause problems for my Adrenaline software which works with an older version of QT. If I install QT 7.0 is there any bugs or problems that may occur? One version of Adrenaline is pre 2.0, and no I haven’t got Avid support.
    Thanks for any help!
    Carlos E. martinez replied 20 years, 1 month ago 3 Members · 3 Replies
  • Ron Lindeboom
    July 31, 2006 at 3:26 pm
    I wouldn’t do it. It is a recipe for disaster.
    But if you really want to do it, here’s a safe way: A way to test it would be to buy a new drive (they’re pretty cheap right now) and do a carbon copy of your start-up drive and then update that drive. See what happens. That way, when you run into problems, you can always go back to the unmodified original drive. If it works (which I would highly doubt), you could then always change to the newer drive as your start-up and use the older drive as a back-up safety net drive.
    Best regards,
    Ron Lindeboom
  • Jimbow
    July 31, 2006 at 3:33 pm
    Thanks for that Ron, I had a horrible feeling I’d be asking for trouble. I just needed to hear it from someone else!
    Thanks again.
    JIM.
  • Carlos E. martinez
    August 3, 2006 at 11:41 pm
    This potential updating problem is dangerous just for Adrenaline or for other versions like Xpress too?
