Activity Forums Creative Community Conversations Updating Projects and Events to 10.2.1
  • Updating Projects and Events to 10.2.1
    Posted by Sherril Schlesinger on July 19, 2015 at 8:32 am
    A client just dropped off a drive with an “easy” fix on X, however his projects are from a previous version of X and I cannot update his Project/Events. I have placed them on an external drive in a
    Final Cut Projects
    and a
    Final Cut Events
    folder…..and when I navigate via LOCATE from File > Update Projects and Events…..I get a message that says
    “Final Cut Pro” could not find any projects or events to update”
    Does anybody have a clue what I am doing wrong.
    This “easy” fix has taken way too long and I haven’t even be able to open the project!!
    Sherril
    Noah Kadner replied 11 years, 1 month ago 2 Members · 3 Replies
  • Noah Kadner
    July 19, 2015 at 3:04 pm
    Make sure the events and projects match in their respective folders. This thread may help: https://forums.creativecow.net/thread/344/26709
    Also as a bit of business advice: when an easy fix turns out to not be, it’s wise to inform your client their project may involve more $ before taking tons of extra time to actually accomplish it.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Sherril Schlesinger
    July 21, 2015 at 1:30 am
    Hi Noah,
    I got the Projects and Events to update but all of the media was offline! When I tried relinking it wouldn’t because the “attributes” were different. I’ve run into this before! I found it very useful that I could override that dialog in 7…..is there a work around in X when that happens?
    Sherril
  • Noah Kadner
    July 21, 2015 at 3:12 am
    It depends on the media. If it is identical it should reconnect. If it’s not- well… it would be good to track down where it’s different.
    Noah
    Call Box Training
